Tempered or normal clear glass?
Posted by: vampyriaerotica on 11 May 2005
Hi,
I'm getting some quotes for pieces of glass as isolation under equipments.
Can anyone evaluate if there's any sonic difference between tempered and normal clear glass and the price differential are by miles away.
Posted on: 11 May 2005 by Dougunn
Hello again
I use tempered glass with polished edges.
It is also tougher than normal clear glass.
Doug
Doug
Posted on: 11 May 2005 by joesilva
I believe that the glass on the Fraimes are tempered. However, the Fraimes are quite a complicated mixture of glass, stainless steel balls, MDF and steel spikes. Therefore, you would probably need to experiment to determine whether "regular" or tempered is most suitable in your set up.
regards,
Joe
regards,
Joe
Posted on: 11 May 2005 by vampyriaerotica
quote:Originally posted by Dougunn:
Hello again
Doug
Hi Dougunn,
I was hoping for your reply!
Posted on: 11 May 2005 by GuyPerry
Vampy, I would certainly use tempered glass in the home, there is an element of safety.
Normal glass creates nasty shards and therefore very dangerous, especially if there is kids around.
I believe that everything produced on a commercial level has to have tempered glass, coffee tables, cabinet doors etc.
I would certainly pay the extra.
Guy
Guy
regards,
Joe
I'm currently using a piece of granite use in kitchen as hard top and very please with the result especially enhanced by sitting it on ss ball bearings.
Vamp
Honestly I didn't do any comparison between regular glass vs tempered. I went for what was closest to Naim's Fraim - thinking they had probably done the comparison already.
Mind you, there is probably some EU regulation stipulating the use of tempered glass (as it is safer).
I would like to tell you what I paid for mine but I can't honestly remember! Do shop around though as this is the kind of thing (in my experience) that can vary wildly in price.
What I can tell you is that glass does introduce a lean fast quality to the sound - which compliments Naims house style greatly. Incidentally I am currently having some interesting results using glass shelves on top of BASE isolation shelves. These are, on their own, not good but (so far) used with glass shelves the results are startlingly good.
Good luck with your experiments.
Doug
Doug
Cheers Doug! I suppose around £65 for 3 pcs of tempered glass arent that bad.
Posted on: 11 May 2005 by kuma
quote:I believe that everything produced on a commercial level has to have tempered glass, coffee tables, cabinet doors etc.
From what I understand, a Mana glass is not tempered.
It's supposed to be regular glass with all sides polished with damping strips. ( to minimise the ringing I guess )
I haven't ABed it with a Fraim glass.
Altho, I am risking to be called mad, listen to the both sides of a Fraim glass. They sound different.
What's ringing?
Vampy, ringing is the glass resonating, due, usually to sound.
Kuma, to sell products like Mana stands in the EC the glass has to be tempered, or have some form of toughening, or laminating. Regular glass is not allowed on safety grounds. I don't think Hi-Fi is excepted.
Guy
Guy
quote:Kuma, to sell products like Mana stands in the EC the glass has to be tempered, or have some form of toughening, or laminating. Regular glass is not allowed on safety grounds. I don't think Hi-Fi is excepted.
ah.. then I stand corrected.
Posted on: 11 May 2005 by J.N.
My friend Martin Payne (who has been absent from these pages of late) has experimented with this, and found that the two types of identical looking glass do indeed produce a different sound from the piece of kit that they support.
I can confirm that Naim Fraim glass is toughened to meet the safety regulations.
John.
John.
Posted on: 12 May 2005 by PS
quote:I suppose around £65 for 3 pcs of tempered glass arent that bad.
....that's about what I paid for tempered glass.
....by the way, I have experimented extensively with tempered glass on spikes/ball bearings with the electronics in a different room to the speakers (minimizing airbourne vibration), thinking that this would be close to Fraim principles, however when compared it to the real thing, Fraim blew my home made hotch potch into next week....
....something very special going on with Fraim. The whole is so much more than the sum of the parts IMHO....
Posted on: 12 May 2005 by vampyriaerotica
PS,
Thanks for clearing this out. However, considering the price difference of 1000:1 between the "real" thing and home made glass and ball bearings, it justifies themselves for the layout IMHO.
In life, you always get what you pay for!
