Infrasonics
Posted by: Johns Naim on 06 March 2003
Greetings All,
As I now seem to be making a few tentative footsteps into the heretical arena of Home Theatre, re an 'add on' to my Naim system, I will need to start considering the addition of a sub woofer.
It seems to be an area fraught with some difficulties re finding a product that will interact in a suitable manner with the SBL's.
Personally, I find the bass of the SBL's quite superb, and don't want to 'mess' with it. However I'd like to consider a sub for LFE if I could find one that would extend the range downwards in the bass of the SBL's without affecting PRat etc, as even on movies, those qualities have a most positive influence upon the enjoyment of the movie experience, albeit not quite as 'critcal' as music.
As a starting point, I would be interested in the REL Q400, or the Strata 111, as they are both acoustic suspension/sealed box bass loaded units, which I would prefer over a ported design. Are they both suitable for HT, and some music use, or is it that the Q400 is mainly for HT, and the Strata for music? Could they sucessfully do both?
The other brand that interests me, although I've never heard them, would be the higher end M&K designs with their 'push/pull' speaker designs, said to give very fast transient response, and slam, which interests me.
Still, I've really only briefly heard a Strata 111, and liked it, but need to investigate what's available and likely to suit the SBL's, and hence would greatly appreciate the input from others who may well have tried some of these subs, or had experience with other high performance/Naim suitable devices.
As always, thanking you for your input,
Peace to All,
John..
Populist thinking exalts the simplistic and the ordinary
Peace to All,
John..
