AV2 sensitive to mains pollution!?
Posted by: Adrian F. on 13 January 2004
Hello everyone!
I recently extended my naim stereo system by adding an AV2 and NAPV175. Now I get goosebumps even with movies, not only music Big Grin
But I added an annoying problem too. When use the AV2 to listen to DVD over a coax-digital cable, or the TV over standard RCA cable, I get "pop" noises induced somewhere to the front speakers. They are irregularly - but every few minutes. Sometimes they are quiet like a static click or a little scratch on vinyl, but sometimes it pop's as frightening loud that I almost fell of my couch and fear for my speakers... Frown
The same DVD and TV where directly connected to my NAC252 before and never made problems like this. I found the light switch in this room to induce loud pop's like this when the AV2 is on (even when muted but on the av input). With the AV2 in standby and only 2 channel use over the 252 there is no problem.
Could the new AV2/NAP175 be faulty? Anything else I should check?
Thank's a lot for any experience in this area!
happy listening
Adrian
[This message was edited by Adrian Frauchiger on TUESDAY 13 January 2004 at 12:19.]
Posted on: 13 January 2004 by Ancipital
Quick question.
Do you have the all of your hi-fi equipment plugged into the same couple of sockets or are they split across a number of sockets? I've had this problem recently and moving all the hi-fi/AV equipment to the same set of sockets has fixed it (although due to something else my 282 is going to have to go back to Naim).
Steve.
Posted on: 13 January 2004 by Adrian F.
Hello Steve
Thank you for the idea. But every HiFi/AV equipment plugs into the same wall outlet connected via a multiple-socket mains block. I didn't change anything with the existing equipment (look at my personal profile). Just added the 2 multichannel boxes, and connected the AV sources from the 252 to the AV2. That's what leaves me a bit helpless - where does this sensitivity suddenly come from??
There is no separate spur. But I don't want to spend money in this rented flat, because I intend to move to something bigger this year. I'm perfectly happy with the sound, when the stuff woulden't "pop". Mad
It was one additional reason to the musical quality, ect. to go the naim-route in AV too. Proper star-earthing, seamless integration, same consistent concept, ect. Hoped to save me from this kind of problems.
Don't know - probably I'm looking at the wrong places... Richard, Manu, anyone, Confused
happy listening
Adrian
Posted on: 13 January 2004 by Manu
It looks like digital errors. This is quite frequent on digital broadcasts (digital sat TV ...) but from a DVDP, strange.
Is your DVD player OK, try an other one if you can.
Check the AV2 software version: you should read P106 or AVC0102, To have it, press and hold OSD on the remote. If lower versions, make them updated by your dealer.
Emmanuel
All opinions are my own, and reflect those of the organisation i work for, even if not stipulated.
Thanks a lot Emmanuel for your experience!
The DVD never made problems - but it is the first time I use the digital coax output to the AV2. Before I only used the analogue RCA L+R channels to the 252.
But it pop's also when watching the analogue built-in cable tuner from TV via RCA L+R. Which it did not with both sources direct to 252 before...
I'll check the software versions when I'm back home.
happy listening
Adrian
It looks like it is the AV2. The analog TV goes to the AV2 on an input which is not set as "direct", so it is converted to digital and back to analog.
Is there distorsion along with the clicks?
IIRC, the sofware P104 does that sort of bug.
If it is the problem, you can temporarely solve it by powering on the sources (DVD, TV) BEFORE awaking the AV2.
Emmanuel
So, back home from work and a little sport.
You are right Emmanuel. Normally I use Neo:6 or ProLogicII to "blow up" the stereo TV signal to all speakers (especially with movies or live concerts) - so it gets the A/D -> D/A treatment.
I switched the TV on before waking the AV2, but it keeps on poping. No distortion, the pops are like a "second layer" over the clean sound. I switched the TV input to direct mode, to track down if this helps.
When I press the OSD button for a few seconds it goes:
VOL 25 -> AVC0101 -> F421 -> VOL 25
so there is a newer software available?
Thanks and good night
Zzzzzzzzzz
happy listening
Adrian
You have the latest PIC in your AV2, but not the last software version. Ask your dealer for AVC0102. Or contact Naim Service Department directly if he doesn`t have it.
Emmanuel
Posted on: 14 January 2004 by Adrian F.
Hello Manu! I guess I live 6 hours earlier here than you...
I mailed my local dealer because of the software. Most naim dealers around here are more conservative with good know-how in classical hi-end, 2channel area. The hometheatre dealers instead have knowledge about beamers, videoscalers, ect., but think with a fat receiver, over 100 connectors on the back and tiny satellites the sound-heaven is reached Razz
The direct mode was not the solution, so the pops come from somewhere else. Because of short space, the TV/DVD/VCR is separated from the full naim rack. So I had to take a 3m long digital coax cable from DVD to AV2. Because the local naim dealers had the preferred Chord ProDac cable only at 1m on stock I took a cheaper Bandridge Profigold cable from the homecinema dealer. Since the cable runs about 2m parallel with the speaker and mains cables, could it be, that it the pops gets picked up there (bad shielding)? I pluged the cable out of the AV2 and for about 30min I had no noises, but late night it was less often anyway. So I keep on testing. Could a digital optical cable help, if this is the point where it gets the pops?
greetings from switzerland
happy listening
Adrian
Posted on: 14 January 2004 by Derek Wright
Adrian - just sent you a pt on an unrelated subject
Derek
Derek: Your pt is answered. For the curious - it was about a former employer not hifi...
Alex: The Update is not yet made. My dealer just phoned me back. He hasn't the software, so he goes to the distributor and he probably to naim. I post back if the new software is installed, but I think it will take a few days.
The entertainment system is at home - but unfortunately I have to work now and then Wink
There is only the analogue connection from the TV and the digital connection from the DVD player. The last thing I did yesterday night, I pluged out this digital cable from the DVD to listen to TV. No pops for the short test, but I'll test it for longer this evening when I'm back home.
For the cable - I meant it the other way round than you seem to think. I assumed that peaks on the mains cable could have induced these pops to the digital cable.
happy listening
Adrian
Posted on: 14 January 2004 by Manu
This 3 m digital cable can be the problem. You will have to try the DVD close to the AV2.
If clics happens also on cd playback from the DVDP, just place the DVDP close to the AV2 with a short cable and try a CD (so you don`t have to plug the video).
With this kind of length, impedance matching becomes critical. A good old RG6U can be better than "Home Theater cables".
Emmanuel
Posted on: 14 January 2004 by karyboue
Couldn't it be more simply an earth loop problem ? I have the same poping with a Rotel 1066 + V 175 connected to my NAC. Sometimes it pops but I know it's my refrigerator ...
I used a voltmeter to plug all the elements the right way. With the V175 there is a problem I can not solve. Pluged the right way : center channel's ground is high and rear is low, pluged the wrong way center is lower but rear higher ...
And I forgot just for the fun. Every morning by 6, my V175 snores for half hour.
Karyboue,
Je ne suis pas sûr que je comprends ce que tu veux dire au sujet du 175.
Les masses des 3 speakers sont communes et communes également avec les masses des entrées.
Emmanuel
Originally posted by Manu:
Karyboue,
Emmanuel
Salut,
Je te passe un lien car c'est compliqué à expliquer : http://www.hifi-cables.com/sens.html
Le problème avec le 175 est qu'avec la prise électrique dans le bon sens, la mesure sur la Din centrale donne une valeur inférieure à la Din arrière. Si j'inverse la prise, la valeur sur la Din centrale augmente et devient supérieure à celle prise sur la din arrière qui elle a baissé Confused .
J'ai bien pensé à supprimer la terre mais je prends toute la pollution des voisin par la prise d'antenne TV collective.
L'autre solution est de n'avoir qu'un appareil connecté à la terre mais j'ai essayé et ca ne marche pas du tout.
Quand au "ronflement" du 175 à 6h du matin tous les jours ce n'est pas une blague et ce n'est pas un ronflement d'enceinte mais bien le 175. Ca dure 1/2 heure et ca donne l'impression qu'un petit bonhomme se sert de mon 175 comme salle de bain et utilise son rasoir électrique Wink .
Karyboue, check your Private Topic.
Emmanuel
