Which interconnect to and from Tom Evans Groove to 52
Posted by: RICHYH on 21 February 2002
Any advice welcome on the findings of interconnect to and from Tom Evans Groove to 52 Pre Amp. I'am currently using Linn interconnect and like it alot, and want to keep all the "life" and depth in the music but would like it if I could add a bit more Bass Slam.
Just changed(this week) from naxo 3-6 to Snaxo 3-6 ------wow what a differnce!! So maybe it'll need a bit more run in time.
Posted on: 21 February 2002 by Frank Abela
Chord Co. Anthem (I've used it direct into DIN and using a Mayware adaptor with similarly good results)
Chord Signature (must use Mayware, but it makes a difference - the question is if you prefer it!)
Both of these would improve things significantly over the linn interconnect, especially in terms of resolution and pace.
Frank.
All opinions are my own and do not reflect the opinion of any organisations I work for, except where this is stated explicitly.
Posted on: 21 February 2002 by Top Cat
...but I suppose a lot would depend on what interconnects you are using throughout the rest of your system, and of course your budget (which I expect for mere mortals rules out Valhalla!)
If you use one brand, it's probably safe to say that you should stick to that brand. Most brands have a lot of good cables a bit further up, although the very best cables can be very expensive and lilac big grin
TC '..'
"Girl, you thought he was a man, but he was a Muffin..."
[This message was edited by Top Cat on THURSDAY 21 February 2002 at 18:44.]
