Dino Ciani Plays Beethoven
Posted by: Todd A on 04 February 2006
The sound quality of this cycle is abysmal. I’ll just get that out of the way immediately. I mean really, it’s bad. At its best it’s barely tolerable. At its worst it’s close to unlistenable. It’s worse even then Walter Klien’s Brahms recordings. That’s bad. Of course, that’s all that can be expected. This entire cycle was recorded over a period of a few weeks in the fall of 1970 in Torino, Italy. Dynamic’s liner notes state that one Uhre (?) mono tape recorder was plopped in the center of the poor sounding hall for all of the recordings. That means that one gets to hear the audience quite a bit, too. The piano is distant and can ring, bite, glare, and grate all at the same time. There’s pitch distortion, wow, drop-outs, overloading, and pretty much anything else that can go wrong with a “modern” tape recording. Schnabel’s set sounds better. I had to get that out of the way early so I could then focus on the playing.
Effortless. That’s the best way to describe Dino Ciani’s playing in the first batch of sonatas. The music all seems to emanate effortlessly from him, with little in the way of forced music making getting in the way. At times, he sounds, well, “natural.” I usually dislike that description since it is, in reality, meaningless. There’s nothing natural about playing the piano. (I suppose singing can sound natural, but that’s about it.) But, at times, Ciani does indeed sound natural. But not all the time. And effortlessness does not always sound extremely satisfying.
Let’s begin. Ciani sounds like he’s in his element with the Op 2 sonatas. The first sonata opens with an Allegro delivered with what, for me, is the perfect overall tempo. It’s quick but not blazing fast. Ciani’s rubato sounds glorious, and even better is his effortless, whipcrack dynamic control. He can move from a nice enough piano to a thundering forte or even fortissimo with an ease bordering on swagger, and his left hand power is at times overwhelming. (Ultimately, these two skills prove to be something of a liability.) Perhaps most remarkable of all is how, in spite of the bad sound, Ciani never comes across as sounding hard. And his control of every aspect of playing is (near) total. He’ll alter the tone, dynamics, and speed of his playing from figure to figure, and within an arpeggio. It’s quite a display. All the while, the music just flows along. Ciani’s strengths are such that one forgives the few slips, most of them minor, though he rather fudges it at 3’55”. The Adagio, too, just flows along, and every time Ciani sees fit to throw in an interpretive touch, it sounds like it’s meant to be! Helping things out is his ability to make the piano sing; it’s bel canto from the ivories if ever I’ve heard it. The Menuetto is taken fast and possesses a pleasantly relentless forward drive. Note that. And the Prestissimo conclusion ends the piece in a hard driven, propulsive way. It’s definitely exciting, though one wishes he could muster the same type of grooviness of someone like, oh, say Gulda, to aid things. As it is, it’s more than fine.
The second sonata continues in a similar way. The Allegro vivace open sounds, well, natural. The tempo is just right, and all other elements of the playing are spot on. Even when Ciani decides to slow things way down at around 50” in, it sounds good, especially since he does to draw out the contrast in the material. His runs are quick and gossamer light, at least when he chooses, and if one might cringe slightly at the miss just before 4’, the thrilling crescendo that follows erases any concerns. Ciani does make the rare decision to play the last repeat, though his disjointed open to it makes it seem as though he merely forgot to play the coda. No matter, the music is fine, though he makes no better case than Ikuyo Nakamichi for playing the repeat. The Largo appassionata is that rare example of both parts of the indication being given equal weight. It’s slow, but it is passionate. That whipcrack control makes itself known in sudden forte outbursts as well as a ferocious – pretty much literally – climax centered around 4’10”. The Scherzo opens with delightful, light repeated figures before switching to a singing tone that one can’t ignore. And it proceeds thusly until the Rondo conclusion, which again alternates between beautiful, controlled, singing playing, and thunderous and fast playing. That’s two winners down.
The third sonata opens with a fast ‘n’ fluid Allegro con brio, with nice accents showing up everywhere, some powerful bass, and some startlingly sharp transitions. It’s a rollicking and rambunctious good time. The Adagio opens in surprisingly touching fashion, and continues on with some well controlled bass crescendos while moving inexorably yet smoothly forward. The Scherzo here starts slower than I would have anticipated, and it sounds a bit congested and almost stiff at times, with Ciani’s powerful punctuations adding to that perception. When the music unfolds into the quicker passages, Ciani seems more at home and the music flows better. The concluding Allegro assai takes off in a fantasia –like way, with Ciani gliding over the keys with a smooth legato for the left hand playing to support a flighty right hand. It’s, well, it’s radiant. So, Ciani opens with some extremely fine Op 2 sonatas, which is a good sign.
Doubts start to arise in the Op 7 sonata. The opening movement starts off with elongated left hand phrasing underpinning a more “standard” right hand, which then gives way to a flowing, swiftish, singing playing. Ciani’s trills swell and take center stage, and the left hand playing is solid, but his playing begins to take on a slightly aggressive mien that really doesn’t suit the music. The Largo opens in slow ‘n’ beautiful fashion, but the forte playing is just too aggressive, though it never really sounds hard. After the aggressive playing, things revert to a leisurely pace and approach more befitting the music. In the middle section, Ciani pounds away with his left hand and follows it with the three-note treble figure in a nifty if somewhat superficial way. Yes, he can do it. What does it signify? Anyway, more lovely, singing playing ends the movement. The Allegro, again, opens in lovely fashion, though, again, some unpleasant aggressive, un-fun playing creeps in afterward. The concluding Rondo is pretty much uniformly superb, relaxed and sunny. However, the piece isn’t a total success. Ciani’s tendency to play aggressively, his tendency to force the music at times, begins to lose its appeal. Adding some bite to the openers is fine, but this piece needs something more.
Moving to the Op 10 sonatas reveals the extent of the issue. The first sonata Allegro molto con brio launches into being, with some of the fastest, most aggressive (though here that’s good) playing I’ve heard. Ciani then effortlessly transitions to his smooth, singing style, and then alternates to the end. The improperly tracked Adagio (it starts with a few second left in the opening movement track) is played attacca for some reason, but it’s beautiful and lyrical to start. Then that too-aggressive playing returns and exaggerates the contrasts in the piece and sounds out of place. It’s here that I began to doubt the “legendary” or other overblown reputation assigned to this pianist by some of his supporters. (I expect hagiography from marketing folks, so the Dynamic copy is to be expected.) Time and again, Ciani resorts to the same basic set of interpretive devices. He plays soft and light and quick (or maybe slow), and then he pounds out the music; he moves from a pp to ff(f?) to exaggerate musical contrasts. Sure, his rubato, singing approach, and generally clear touch all sound wonderful, but his overall framework is somewhat simplified and limited. Anyway, he ends the piece with a very fast, very powerful Prestissimo, but one that, given its fixed parameters, ends up sounding more like an athletic exercise than a musical one.
The 10/2 is much the same. The opening movement is fast and shimmering and singing on the one hand, but aggressive on the other. His sharp, strong forte and fortissimo playing is superficially exciting, but it lacks much beyond that. The Allegretto actually ends up sounding sub-par. Ciani pushes it very fast, perhaps in an attempt to sound urgent or substantive, but it just sounds too fast. The repeatless Presto is fast and reasonably good, but it, too, lacks anything to really recommend it.
Perhaps it shouldn’t be surprising that the 10/3 sounds much the same. Ciani opens the opening Presto at a breakneck pace. He throws in his usual assortments of goodies, but it’s pretty much a straight shot through. The Largo is certainly slow, but it’s curiously flat and unusually garbled. Perhaps it’s meant to be “emotional,” but it sounds more like an eidolon of emotion rather than the real thing. Fortunately, the Menuetto returns to Ciani’s effortless, attractive playing with nary a complaint for me to make. The Rondo, though, is also taken at breakneck pace and suffers. It’s decent, but not great.
So, I guess I’m left with recordings by a supposed wunderkind – he was only 29 when he recorded his cycle – who just doesn’t live up to my expectations. Don’t get me wrong, Ciani’s playing is at times amazing, and at his best, he really does have a lot to offer. He just doesn’t offer more than anyone else. Indeed, in all of the first seven sonatas I can think of several (or more) versions I prefer in each work. Of course, it helps to keep in mind that this is a young man’s Beethoven, and I will keep that in mind going forward. Ciani, like Yukio Yokoyama, Alfredo Perl, and Friedrich Gulda (okay, maybe not Gulda), apparently hadn’t formed his ideas completely, or formed ones likely to change and evolve. Anyway, I still look forward to hearing what else he has in store, even if my expectations have dropped a bit.
