DIY phonostage with 522 boards
Posted by: Mike.S on 11 January 2004
522/2 Boards
Just a quick question. I would like to use some spare 522 boards and flatcap1 to make
a phonostage. My question, does anyone know
the phonoboard pinouts.
I would imagine this will give me something
close to a stageline.
Thanks in advance
Mike
Posted on: 11 January 2004 by Manu
If you are not able to figure yourself the pinout of 522 boards, i doubt (sorry) you will be able to build a good phono stage.
Emmanuel
All opinions are my own, and reflect those of the organisation i work for, even if not stipulated.
Posted on: 11 January 2004 by NaimDropper
Kinda harsh, don't you think Manu?
Maybe he's just verifying the pinout and is perfectly capable of making a decent enclosure and connections. Didn't state that he was building the world-beater phono stage, just asking for the pinout...
Check your PM, Mike.
Yes, maybe. Sorry Mike if it offends you.
What i meant was 522 pinout is quite straight forward and taking the time to find it out is IMHO a good starting point.
If you take good care and time, you can build a terrific phono stage.
Mike, my advice is to ask a guy knowing electronics to check your work before powering it.
The most expensive repairs i do on Naim units is on modified ones.
I know almost nothing in mecanics and I don't play with my car engine.
Emmanuel
