Is it worth to replace a flatcap with a Hicap -
Posted by: Arye_Gur on 10 February 2002
for a Cd3/Flat,92,90/Credos ?
Arye
Posted on: 11 February 2002 by Jay
Hell YES Arye!
But better still, keep the Flatcap - then decide what you want on the CD3.5, the Flatcap or Hi-cap.
Jay
Posted on: 11 February 2002 by Arye_Gur
Hi Omer !
When can I come and listen to your new speakes ?
This is a friend's system - who has now the possibility to buy a HI.
Arye
Posted on: 11 February 2002 by Steve G
I'd consider replacing the 90 with a 140 first as it works a lot better with Credos.
Steve
Posted on: 14 February 2002 by Martin C
Hi Arye,
As Jay said, it's definitely better with Hi-cap on CD 3.5, than flat cap. I used to have the 3-serie set up, CD3.5/92R/90/3 and Intro. Then got 02 flat caps on CD 3.5 & 92R, it's obviously improved the clarity and soundstage.
To replace with a Hi-cap, As I got all these brand new, so it's not cost effective, the cost of Hi-cap and CD3.5 is almost like a CDX, CDX is definitely better, it's depends how much can you get for your CD3.5 and how many you pay for the Hi-cap. Otherwise better get a 102 or CDX.
cheers
Martin
