For technical people
Posted by: JohnMak on 15 March 2003
I've been reading a lot of the posts on this forum and the Linn forum and I keep seeing references to newer Linn equipment using "Bright Switched Power Supplies". The blurb seems to imply that they have now done away with any need for add-on power supplies for the Linn upgrade path and which of couorse are a significant cost in the Naim upgrade path.
I went to the Linn web site to try and see how they work but they don't say much other than it has done away with the need to use the big, heavy toroidal transformers, it produces clean, silent power at all levels regardless of the condition of your mains etc.
They show a slim looking amp called Klimax which is claimed to be 500W .... but it only looks about two inches thick???
Can anyone tell me if Linn have made a quantum leap forward in amplifier design and performance with switched mode power supplies? Or is it just "marketing"
Cheers.
Posted on: 15 March 2003 by Mr_Sukebe
Everything in life is a compromise. Chord have developed similar technology for using fast switching power supplies. I believe it's similar logical technology to that used in power supplies for PCs.
As for benefits, well obviously Chord and Linn think there are some, whereas other manufacturers believe that it causes compromises elsewhere.
Frankly I wouldn't worry about the technology that's in your hi-fi. Just listen to it. If it sounds good, it is good.
Posted on: 15 March 2003 by Andrew L. Weekes
Linn use what would normally be known as switching power supplies (switch-mode power supply, or SMPS).
These are used almost everywhere today, as they offer very high powers, from much smaller more efficient and cooler-running units. I won't go into the details of why here, but a web-search for SMPS + efficiency will probably get you all you need to know.
Other potential advantages are that because the energy in the PSU reservoir capacitors is being replaced more quickly, and at a frequency above audio (usually) they can cope with musical power demands much better.
The downside is they are all noisy - Linn claim to be able to make them quieter than conventional supplies, to which my response is their linear supply designs must be very poor indeed!
They are much harder to design, and also tend to radiate electro-magnetic interference unless well screened and designed.
Frankly there is no way on earth you can make an SMPS PSU quieter than an optimal linear supply, without degrading most of the benefits of SMPS in the first place.
They do have very real benefits that make them worthy of consideration - maybe when followed by a high quality linear supply.
Additionally they need mains input filtering to comply with EMC regulations, and Naim systems don't like these filters on the same mains sockets as the system.
Six of one, half dozen of the other...
Andy.
Posted on: 15 March 2003 by Bob Shedlock
As with a great many things electronic, it is the implementation, not the ideology. A good idea poorly implemented is a "mistake"!
I beleive Andrew pointed out in another post regarding circuits in naim amps that the devil is in the details.
There's still no magic bullet.
Posted on: 15 March 2003 by mdurand
Also, switching PSUs have the nasty habit of launching a whole lot of nasty harmonics on the mains side.
The DC going to the device's internals might (and that's a big if) be clean but the rest your system will have deal with the pollution.
Also, if your utility's power isn't very stable frequency wise, the switching PSU's high frequency will have to compensate... can anybody say FM source ?
For kicks, plug and fire a desktop computer (even with a top notch PSU) on your wiremold power bar
Martin
PS: First post, woopee
Posted on: 15 March 2003 by Manu
Salut Martin,
Welcome to the Forum.
Emmanuel
All opinions are my own, and reflect those of the organisation i work for, even if not stipulated.
Posted on: 16 March 2003 by raymond
Andy.
Thank god there are people on this site like you Andy....With something important to say. If I get banned so what...but this site is going down bank. Regards, to them that actually have something interesting to say.
Regards, to them that matter.
Hi-Fi a means to an end.
Posted on: 17 March 2003 by Andrew L. Weekes
For those of a technical persausion, the application note below provides a vast array of very useful information about switching power supplies and noise reduction.
http://www.linear.com/pdf/an70.pdfCool cartoon on the last page...
Andy.
