Calling all Dynavector P-75 owners
Posted by: quickie on 25 January 2004
Is the power supply supplied with the P-75 in the UK/US just a bog standard wall wart type affair?
I have found a good deal on one from overseas,but it's not available with the UK type P/S.
Paul.
Posted on: 25 January 2004 by custard
Ive borrowed one from my dealer for a few days the power supply looks like a cheap one available for a few pounds.
Posted on: 25 January 2004 by Energy
Here is part of any email sent to me from Jonathan at Dynavector.
The P-75 requires an ac adaptor 12V DC 500mA You can get one almost anywhere between $10 & 20. I am going to get a bulk lot for Australia and NZ and if they get here in time I can supply you with one. As you will read in the instruction guide, the ac adaptor makes no difference to the sound.
I have even tried battery powering the P-75 and built my own power supply, the cheap wall plug pack sounded the same. I'm now just use the plug pack again it works and sounds fine.
Alan
Posted on: 25 January 2004 by quickie
Excellent stuff guys.......thanks.
Paul.
