Advice Time
Posted by: andrew mcmullins on 30 May 2001
Okay I have now worked out my upgrades.
I will do them over this year and next.
Which do people think will provide the most benefit in the short term ? ie. which this yearand which next ?
I know that I will have to go and listen to see which I think is best but I'm asking if their is a perceived 'correct' way. I suppose that closest to the front of the chain is correct but ...
I'm going to change my 72 for an 82 (with a 2nd hi) and change the 140 for 135(x2) - I much preferred this to the 250 and would rather wait than get an 82/250.
I'm driving those forum favs IBLs.
Posted on: 30 May 2001 by Andrew Randle
What's your source?
Once that's sorted, don't bother with a 2nd hi-cap, sell your existing hi-cap and buy a supercap.
Then start thinking about changing your 72 for a 52.
Andrew
Andrew Randle
2B || !2B;
4 ^ = ?;
Posted on: 31 May 2001 by andrew mcmullins
I'm using :
for CD a Roksan DP-1/DA-1/DS-4 (which has just been Attessa'd by Roksan)
for Tuner: NAT-01
Posted on: 31 May 2001 by Andrew Randle
Well that's alright then wink
Time for a Supercap then 52.
Andrew
Andrew Randle
2B || !2B;
4 ^ = ?;
Okay. I'll go listen and then obtain. I'll let you know when its in place (well the supercap anyway).
Posted on: 31 May 2001 by Jay
Can you actually use a Supercap with a 72?? I thought you were limited to a Flat or Hi-Cap.
Jay
Posted on: 31 May 2001 by NigelP
You will get much more benefit this route than using a 82 with the 135's. Also you'll be in great shape for a 500 if luck is on your side in a few years time!
