Premature NBL Upgrade
Posted by: Jeb on 18 December 2001
102/PSC/180/HI-CAP/3.5/FLATCAP/SBLs
I would like to hear more of the lower end and open a new upgrade path to active salvation.
Is an NBL upgrade advisable given my source constraints? What could I expect with a 102/180/NBL combo?
Jeb
Forget about the NBLs. If you want more bass, start at the source. You'll be surprised what a difference a better CD player or preamp makes. The biggest "lower end" improvements in my system came when I moved from CD 3 to CDS and NAC 102 to NAC 52. I was never too happy with the NAC 102, I felt my system sounded "thin". Ask your dealer if you could try a CDX and/or a NAC 82 for some days at your place. You'll hear it for yourself!
Ciao!
Willem
In fact, if you're thinking about NBL upgrade money, then apply that same amount to a CD upgrade. I would suggest you shoot for something like CDX/XPS/82/Hi/180/SBL. That should be a nicely balanced system (although some would suggest you go for CDS2/102/NAPSC/Hi/180).
-=> Mike Hanson <=-
You could spread the cash differently and open up an upgrade to active if you really wish with another 180 plus SNAXO/HiCap. the front end will still be holding things back though.
Personally I would look at CDX/XPS before touching anything else (or CDS2 as mentioned). the SBL's in your system have lots of untapped potential. Bass is not just speaker dependent, CDX and especially the CDX/XPS combo altered mine beyond measure. If a home dem fails to convince then get the dealer to check the SBL set up too.
Bruce
Thanks again!
Jeb
