Good supplier of electric blackout curtains for HT
Posted by: PatG on 21 November 2005
Hello
Am needing to install curtains/roller blinds for my home theater room that will respond to a remote control.
I am not in need of complete blackout blinds.
Anyone has experience of a good supplier?
Thanks P
Posted on: 21 November 2005 by arf005
Pat,
might not apply in your case, but we used velux....
We converted our only upstairs bedroom into our Den, it has two velux windows, input the serial number of the window and the velux website tells you which blinds you can get. Ours colour matched the room and are aluminium foil backed - black out and heat reflective/absorbent....
They're manual pull down but can be fitted with battery motors for remote control use....
Really only suitable if you've got felux windows though I guess......
Ali
