CD5 or NAIT5
Posted by: Lightkeeper on 05 April 2002
I will apreciate any suggestion.
Thanks,
Ozren
Originally posted by Ozren Herold:
My system is Arcam Alpha 8 CD player, Naim Nait2, Epos12. Should I buy CD5 or Nait5 first ?
Of those options CD5 - no question.
Of course if you were in the UK you could sell the Arcam and the Nait 2, add the CD5 money and get something like used CD3.5, 32.5/Hi/140 for the same cash...
Steve
I almost think the same. I will go for CD5.
I am live in Croatia, so those shopping oportunities are off. But, just one thing...
Nait2 have a little power to drive Epos12, so I was thinking maybe to buy Nait5. Are you absolutelly shure that I should have a better sound with CD5/Nait2 than Arcam 8/Nait5?
Ozren
I've never heard a CD5 but I do have 3 Arcam CD players and a CD3.5. The CD3.5 is a lot better than the Arcams - the 8 is an ok player but it's really playing in a lower league.
If you need power forget the Nait 5 - you'd be far better off with a pre/power. It might be worth checking out the UK shops to see if they'll ship used kit to you - you should be able to get a 72/140 for Nait 5 money.
Steve
Ideally epos 14's do like something like a 140, 150 upwards, however the nait 5 has a surprising amount of grunt. It has loads more ability at controlling difficult speakers than any of the older naits.
