Where the hells me wires go!!
Posted by: Matt worlock on 15 October 2001
The subject of cable position (speaker cable,interconnects, power leads etc.) in relation to each other is a little bit fustrating to me. When I take a look behind my hifi support there are a lot of cables back there & there all in a bit of a mess really.
Now many poeple have mentioned things like you must not allow cables to run parallel with each other, that the mains socket should be at least 2 feet distance from the kit, speaker cable must not be ran along side or under radiators, mains power leads must clear from signal cable ie interconnects,speaker wire.
To me it seems to be virtually impossible to avoid these so called sonic pitfalls where if one cable gets a slight whiff of another your chances of obtaining good music are trashed!
I'm wondering how exactly this placement problem degrades the sound?
Cheers for now Mad boy Matt
