NAC82 & phono modules
Posted by: Den on 05 March 2002
Ok, I know this question comes over and over again, but searching the forum didn't really give me the answer. Is boardpulling worth it in the case of a NAC82? Anyone on the forum who actually did this? What kind of improvement can I expect?Can I just take them out, or do I have to replace them with blanc cards? When you buy a new 82 are there phono boards installed?
Thank you all,
Dennis
Posted on: 05 March 2002 by davidf
just pull the boards out. no need for blank cards. didn`t notice a significant difference. david.
Posted on: 05 March 2002 by Naheed
I initially replaced the phono boards with blanks (i was told i had to), then finally pulled the blanks as well.
A small noticeable improvement.
naheed
Posted on: 05 March 2002 by Rico
Omer
there's only one removeable board in the 82 - the phono board, which is in line with the BNC jacks. One can insert link boards in this position for direct connection of line level sources via the BNC's (an extra input, effectively)... but thats it. HTH.
Rico - SM/Mullet Audio
Posted on: 05 March 2002 by J.N.
Admittedly I was using a CDS2; and running the 82 off of a Supercap, but I reckon CD sounded quite a bit better with the phono boards removed.
I now use a Stageline; driven off of a Hi-Cap.
Posted on: 05 March 2002 by Den
Thank you all. I think I will take them out. An small improvement is still an improvement.
Dennis
