Qute: turning off the built-in power amp?
Posted by: okli on 23 October 2010
Hi,
nap-ster published here the presentation of naim network products on signals. In the slide dedicated to Qute there is a statement, that the in-built power amp can be switched off in the setup menu - can someone point me which menu item this should be, because I couldn't find anything so far? The manual does not say anything about this as well...
TIA,
Ilko
Posted on: 23 October 2010 by 0rangutan
Yes, this is the right setting.
Qute then just acts as source, DAC and Pre.
Posted on: 24 October 2010 by okli
Thanks - may be this should be documented more clear in the manual - I thought these settings are simply DSP filters applied with "None" meaning no filter at all.
