Internet radio
Posted by: imperialline on 04 August 2008
What do you think of the internet radio?
Some of radio channels seem to be very acceptable to me, for example NPR, Otto's baroque musick and SKY.FM, etc. even they are streaming at 96 kbps or 128 kbps.
I usually stream them from my MacBook to the AE and then to the Lavry DA10 + Nac 252.
Posted on: 05 August 2008 by Paul Hutchings
I have a Meridian F80 fed by an Airport Express.
I listen to a lot of Internet Radio, usually via iTunes fed into Airport Express.
I think it sounds fantastic.
Posted on: 07 August 2008 by Adam Meredith
I listen on an AE box and enjoy the range of stations greatly.
Quality seems fair but (for the moment) choice, and reception, are the main reasons for use.
