Length of interconnect cable
Posted by: FE on 06 February 2004
Is the length of the standard interconnect cable the recommended? Will a shorter cable sound better or worse? I'm up for a test of a cable where I decide the length myself.
FE
FE
Posted on: 07 February 2004 by FE
FE
I'm thrilled with all the respons on my message
Posted on: 08 February 2004 by kuma
shorter the better is my experience.
Posted on: 08 February 2004 by Derek Wright
Response on the forum is slower at the weekend as all the main posters are away from the company supplied internet connections <gG> on long weekends to exotic european cities like Venice - the Copenhagen of the Italy
Derek
Posted on: 08 February 2004 by NB
I have never noticed any difference due to length of speaker cable, but try different lengths for yourself and see which you prefer.
NB
NB
Posted on: 08 February 2004 by Erik
It's strongly recommended not to shorten the interconnect.
/Erik
/Erik
Posted on: 08 February 2004 by Sean Woods
23 miles I think!
Posted on: 08 February 2004 by NaimDropper
I wouldn't make them any shorter than is necessary to connect your kit...
I'm assuming you're talking about making your own interconnects. Make up a short one, just long enough to connect the kit, and then one that's 5 times longer. Make them exactly the same except for the length. Have someone else switch them (so you don't know which is which) and see if you can tell the difference. Try the test more several times and objectively tabulate your scores. This will answer the question for you.
I'll bet you can't.
There are those who claim that interconnect cable DIRECTION is highly detectable, but I'm not in that camp. Naim recommends a particular direction and that's the way I use them but I seriously doubt that anyone could reliably tell the difference.
I'll bet you can't.
