Rec. For Centre Speaker Wall Brackets
Posted by: Mr Underhill on 17 June 2009
There are numerous sites selling the BT15-B brackets - but I'm looking for something that looks more robust. Any Suggestions?
Ideally I would want something similar - that attaches to the wall behind the center speaker - but better made!
Thx,
M
Posted on: 17 June 2009 by lawoftrust
May you would like to consider the Phonosophie Freemount classic. There are several options, it is great craftsmanship and well designed.
http://www.phonosophie.de/Inte...l/eaufstellung4.html
Posted on: 18 June 2009 by Mr Underhill
Thx - I'm also looking at the Target brackets.
M
Posted on: 27 June 2009 by Massimo Bertola
M,
I assume you're not referring to the N-Center: otherwise, what'd be wrong with its own bracket?
In case, I have a spare one.
M
Posted on: 28 June 2009 by Mr Underhill
Thx Max,
No. I've just bought a pair of Living Voice Auditorium IIs for my main stereo duties & so I'm going to hold onto my Skibo centre, that matches pretty well.
Currently I've got it set up on a turntable table - works fine, but I'd like to get it back nearer the wall.
Thx for the offer. If I'd bought the Allaes I would have bought an n-cent as well.
M
