speakers
Posted by: FE on 24 September 2003
With my Naim system ( 2 Nap 135, Nac 52, CDX, XPS and Super Cap )I'm currently using Audiovector M3 signature speakers. But I would like some new, better and different speakers. Budget is about 4500£. I'm also using Naim speaker cable's. Any suggestions for other cable's? Looking forward to your opinion.
Posted on: 24 September 2003 by NB
Hi FE
Welcome to the forum.
Firstly I would stick with the Naim cable as it really is the best cable for anim amps.
As for the speakers, could you strech to a pair of SL2's at just under £5k. They really are a wonderful pair of speakers.
If you can't there are the Neat Ultimatum MFS standmounted speakers at around £3k. They would suit your sistem ideally. If you can strech to the MF5's even better.
NB
Posted on: 24 September 2003 by Lightkeeper
FE,
at your place I will go for SL2, if funds don't allw, then I will go for sl2
Ozren
