Reparing record covers
Posted by: Don Phillips on 01 September 2008
Hi folks
I have tried a Search on this topic, and I am not sure if this is the appropriate forum, so please inform/move/redirect as appropriate..
However, what I need to know is what is the best glue to repair record sleeves that become unstuck. I have tried "Pritt" (not a typing error) and success is short-lived - not strong enough. Any other ideas please
Don
Posted on: 01 September 2008 by Geoff P
Thin double sided sellotape.
Geoff
Posted on: 01 September 2008 by 555
I've found Copydex glue to be best.
Posted on: 01 September 2008 by abbydog
White PVA also works well. I avoid Sellotape and the like because of sticky residues over time.
Posted on: 01 September 2008 by BigH47
Thin double sided tape here also.It's an instant fix for the sleeve edges parting company.
Posted on: 01 September 2008 by JWM
I have tried all of the above.
Watered down white pva glue can be blushed on as a 'varnish' to bond scruffy de-laminating edges of record sleeves (remove record first!).
Copydex has the advantage of being able to 'rub off' any rubbery residue when dry, but is a bit messier to apply.
But for those sleeve edges parting company, rather than any glue I too have concluded that double-sided tape is the most practical solution - it neither risks glue oozing out, and bonds instantly (so you you do have to be good at lining-up straight first time; but I have never found this a problem, and my hand is sufficiently unsteady so as not to risk handling an Aro!!).
James
Posted on: 01 September 2008 by Stephen Tate
Exactly what i use and it works a treat.
I use the stuff made by Sellotape.
Steve
Posted on: 01 September 2008 by Don Phillips
Thanks guys
Looks as though double sided tape has the majority vote.
Although for my Earl Bostic LP I might use some sort of glue. Smile
Don
Posted on: 01 September 2008 by Lapdog
Don, though I used regular Pritt with great success, there was times that it didn’t really hold. For those most stubborn albums I would use the stronger version called “power Pritt”. 3M Scotch glue stick “purple cap” would be another brand recommended by Music Matters (some initial albums came unglued).
Brian
Posted on: 02 September 2008 by joe90
Then put the cover between two heavy chopping boards for a few mins.
If I use expensive, marble chopping boards will my records sound better?
I have some recordings that are bass-heavy.
Would standing the chopping boards on titanium ball bearings have a positive effect on the sound quality?
Posted on: 02 September 2008 by tonym
Nice big staples work well. No good if you happen to like the first track of the LP mind!
Posted on: 02 September 2008 by Guido Fawkes
Take the elpee out of the cover first.
Posted on: 02 September 2008 by 555
