What is the truth with the BASS?
Posted by: Arye_Gur on 09 January 2004
I read the thread about the subwoofer and I wish to as k you a question:
I don't think that the IBL have a problem with bass – especially when I compare them to live music. A live jazz band with a contrabass doesn't seem to have (to my ears) more bass than my system with the IBLs. But it is obvious, when you listen to other speakers than Naim's, most of the times you get more bass than with the IBLs – and when the system does it right, it gives more pleasure to the listening (only I don't know a system that sounds better than Naim in all the other aspects).
The problem is not with the electronics. When I had a CDX/102-Hi-Napsc/140, I took for a listening Obelisk by Shahinian, and these speakers went very low – only the 140 couldn't control them.
Few friends, in order to prove to me that my speakers are bass less, brought to my home Rell Stadum – but nada! With all their affords, the rell gave nothing, and they couldn’t bring the system to play more bass with the Rell.
Few days ago I read that the IBL goes down to 45 HZ. I also know that our brain can recuperate low frequency if the ear receives the second harmonic. So if the loudspeaker plays 45 Hz, you can "hear" a source sound of 22.5 Hz and this is low! It is a fact that you can hear lows even when you are listening to a small radio-transistor because of the facility of our brain to "rebuild" the sound out of its harmonics.
So the question is, what are we missing with the IBLs compare to other speakers. I was told that the problem is with the upper lows, that Naim treat this area differently than other manufacturers.
Arye
Posted on: 09 January 2004 by Mike Hanson
When many people say "bass", they don't mean 30Hz, but rather 200Hz. A subwoofer won't have any impact on that frequency. They also expect boomy bass, which Naim also does not do.
There's fat versus lean, and warm versus cold. In the case of Naim speakers, they are generally very lean and very cold (which is why I don't like Naim speakers).
-=> Mike Hanson <=-
Posted on: 09 January 2004 by Nime
Arye,
Those who ask for more bass than that offered by smaller boxes are looking for rather more than a facsimile of the music. They are looking for greater reality. At least I am.
There is a great deal missing in the reproduction from small speakers that is not immediately obvious. Organ notes, plucked acoustic bass, kick drum & percussion in general are all incredibly demanding of bass fundamentals. In order to have any grip on reality.
I believe strongly that the fundamentals form the leading edge of all transients. This reminds me of an early review of the Linn Sondek. The reviewer said that he believed that every note has to have a starting point. As it is beginning from a standing start it has no frequency. It must start therefore at DC = 0Hz and work upwards. To fill the sound envelope expected by the brain. If the speaker cannot start at a low enough frequency then every single note and sound heard lacks a true leading edge. The brain must work harder to fill in the gaps. Reality is lost. The words are mine. The sentiments are partly his.
I would set the <upper> starting limit for fundamentals at 20Hz from 8 years experience with subwoofers with just that capability. My Mission 753Fs have bass but lack real fundamental depth compared with my subwoofers. So I plan to set up a second system just to enjoy the reality of my subwoofers and Kans. Note that these subs are <flat> down to 20Hz in my large listening spaces & not Home Theatre bloated bass in a small room.
Those who think they have real bass are probably judging it on the bass guitar in rock music. This needs plenty of power to reproduce well but no great bass depth.
Consider yourself incredibly lucky that you are satisfied by 'virtual' bass. Just think of the money you'll save over the coming years on bigger boxes and subwoofers. Smile
Nime
Everyone has the right to be wrong.
Posted on: 09 January 2004 by Arye_Gur
satisfied or not - I'm sure that there will be time when I'll go for bigger boxes ...
Arye
Posted on: 09 January 2004 by Geoff P
Arye
I have plenty of bass in my system. The point behind that comment is that the Naim electronics is supplying that bass sound. With quality speakers it is fair to assume it is not enhanced in any way other than by any bass emphasis built into the electronics by Naim themselves. So that says that, given speakers that can portray the lower bass frequencies and enough control in the amp to give a clean delivery, those frequencies must be there in the recording.
That does not garauntee that the recording is not over emphasised, but it must be so for virtually all recordings I listen to if that is the case, since the vast majority do have deep bass lines on them.
On the basis of this it would seem sensible to use speakers that can play these frequencies if it is practical for your listening environment.
On the comment from Nime I am a little concerned with the idea that a sub or really deep bass frequency response is needed for proper delivery of all notes because they "start" at 0Hz!. If that argument is correct the speed with which the frequency rises, particulalrly on higher frequencies will be an issue. A large speaker cone will need time to move and I would think would be far to slow to keep up with the speed of the higher frequencies.
regards
GEOFF
Posted on: 09 January 2004 by prowla
It's not (quite) right to say that notes start from 0 Hz.
The attack (leading edge) of a note is defined by the HIGH frequency characteristics, not low. A low frequency not cannot give a steeper leading edge than the shape of the sine wave of that frequency.
Of course, music is not made up of simple sine waves because musical instruments and human voices do not output sine waves, but rather a rich mix of frequencies that constantly changes.
Paul Rowlands
That's why they have smaller cones for higher frequencies Goeff. Smile It is only a theory that I found interesting and it has stuck in my mind for several decades. It seems plausible enough. An audio frequency spectrum analyser could probably disprove it at a single stroke.
We are all surrounded in incredibly deep bass all day long: Trains, lorries, carts on concrete floors, supermarket air-conditoning and the pallet truck brought to fill the shelves, are a few obvious examples.
Listening to satellite TV with my subwoofers & Kans <running at normal speaking voice level> is often startlingly real. The mundane detective series suddenly has a real train arriving at the platform, the deep rumble & racket of a steel-wheeled, wooden truck carrying luggage across the concrete platform. The old lorry, bus or car pulling away all excite the senses. These things are hardly noticed on normal speakers yet add so much to the reality of the story telling.
I am talking about speakers/subs with a flat frequncy response down to 20Hz in a large space. Not HT boost with the wick turned up in a small room which has nothing whatsoever to do with everyday reality or music. Even if it is great fun!
So why do many deny themselves the same everyday low frequncy response when they listen to music? Don't they even want to hear the conductor walking onto the wooden stage during a classical music radio broadcast? You won't believe the racket a string quartet can make on a Radio 3 Lunchtime concert as they plod about and adjust their chairs and music stands between pieces. Big Grin
The human ear response falls off as bass drops in frequency. As do virtually all loudspeakers (just to make life even more tiresome). To enjoy deep bass requires a flat frequency response into the very deep bass. Otherwise the wick has to be turned up just to make the deep bass even audible. But this high volume level just submerges it in everything else that is happening. A subwoofer simply offers deep bass at <natural everyday levels> without excessive volume. But only when adjusted correctly and perfectly matched to the satellite or main speakers. Not an easy trick to carry off successfully.
http://replaygain.hydrogenaudio.org/equal_loudness.html
(Offers a nice graph of the equal loudness problem)
Nime
Posted on: 09 January 2004 by MichaelC
Originally posted by James:
The most impressive bass note I've ever heard is the sound of an approaching earthquake in the still of the night. Pure subsonics that no subwoofer can ever hope to achieve with realism or effortlessness.
James
Or the rumble from a volcanoe - damned spooky first time round.
Mike
Posted on: 09 January 2004 by ken c
(5) Tunefulness - how evenly bass fundamentals are reproduced so that a slightly flat low E on a bass guitar is plainly obvious to the pitch perfect ear.
Few, if any, loudspeakers will do all of the above. So you pays your money and you takes your compromises.
James
interesting summary. i am interested in "tunefulness". in particular, how low the freq response has to be to reproduce the harmonics of natual instruments as faithfully as possible without sounding synthesized. is 20hz -20 KHz enough? anyone ever measured "in-room" freq response??
enjoy
ken
Posted on: 09 January 2004 by afshar
Arye,
My experience with IBL indicates that the speakers continue to process more and more clean and accurate bass with every improvement in power and preamp. Going active helps a lot (the IBL needs at least 2 250s to come alive), but when combined with a 52/SC the improvement is dramatic. With the 52/SC the bottom part of the baritone voice finally fills out, without the 52/SC baritones tend to sound more tenorish. The combination also does wonders for solo piano by adding power to the notes. I plan to add the new SNAXO 2-4 sometime this year and look forward to seeing what improvements that will make. But given the above, the IBL still does not bring out the bottom line as well as an SBL.
Ira
Posted on: 09 January 2004 by trickytree
A question. All the reviews on supertweeters that I've come across, ( I've not read the Townsend review in the latest HiFi World however ) have commented that the bass had changed for the good, ( can't remember there precise words ). Why is this? I assume the brain is "tricked" into moving the middle point of the frequency responce? Cant say as I understand such things but I did like my old Infinity Kappa 6's in certain ways with its Emit Tweeter.
Paul.
Posted on: 10 January 2004 by Arye_Gur
afshar,
I had to downgrade from CDX/102-Hi-Napsc/140 to Micromega stage 3/32.5-Hi/90/2. I did this in two stages, the Micromega was the second.
The sound now is far less pleasurable than it was with the former amplification, but there is much more bass now with the 32.5 than was with the 102. (But I'm not recommending of this downgrade!!!).
Arye
Posted on: 10 January 2004 by Nime
I agree entirely with James on the unique quality of all bass notes and sounds. The remarkable diversity of bass notes when heard clearly. Must bring into doubt ideas of the brain being truly able to fill out the missing bottom octave(s). Another hifi myth bites the dust?
Another fascinating area of enjoyment (if only for brief periods Smile) is 'techno'. The lightning speed & timbral character of their electronically produced bass sounds can be quite remarkable when one can really plumb the depths. I wonder how they monitor their own bass lines?
Nime
Posted on: 10 January 2004 by Top Cat
I think I'd find that a bit more thank spooky!
John
TC '..'
"Sun went down in honey. Moon came up in wine. Stars were spinnin' dizzy, Lord, the band kept us so busy we forgot about the time."
Posted on: 11 January 2004 by Nime
I think I should concede that my gushing enthusiasm for my own Kan matched DIY passive subwoofers has absolutely no relevance to most members of this forum.
If you want to get quality sub bass and all its advantages into your own system then you should really be auditioning a Rel active subwoofer with your own speakers. Or rather two Rels.
Their very low cutoff points are able to match floorstanders with already adequate upper bass. If you are serious about realistic sound quality you owe it to yourself to ivestigate active subwoofers. Whatever your preconceived notions about them.
I have just been trying to enjoy some organ CDs again with my late model Mission 753Fs via my 72/180. The Missions really don't have what it takes unaided. Despite my open plan listening space. The Missions are bolted to heavy cast iron Blackfeet stands. (for a large footprint without lifting them off the floor) These sit on large heavy duty concrete paving slabs via huge spikes. But despite all this the missing bottom 20Hz really is essential to the full enjoyment of the music. As my wife keeps pointing out!
If I had a couple of Rel subs I could perfecty match the sub-bass to my Missions. But of course my two passive subs are totally incompatible with the 753s or any other speaker. Mere plant stands. My wife could even use an AV setting for Metallica with a Rel sub (or two)! Peace at last! Big Grin
Don't let my over-enthusiastic waffling about sub-bass put you off having a serious listen to active subwoofers.
My problem now is finding a Rel dealer in Denmark. The one on the Rel website is actually in Sweden.
Nime
Posted on: 12 January 2004 by Laurie Saunders
I agree with james that good transient response(ie rapid rise and fall times and absence of overshoot (ringing)) is the best single indicator of performance of all parts of the hi-fi chain. Get this right and virtually all the other desirable features of good sound quality fall into place
As with all engineering solutions, some compromise is inevitable...it is the mixture of those compromises/choices that gives rise to all the different "flavours" of "ideal" solutions available
For me, slow, loose (ie poorly controlled) bass is one of the worst sins of a hi-fi system...IMHO it robs the music of those qualities that make it enjoyable for me...I would sooner sacrifice bass extension.....other listeners might have different prorities
Laurie S
Posted on: 12 January 2004 by Geoff P
One of the problems I have encountered in attempting to integrate a sub-woofer is I believe a difference in delay time which results from the sub-woofer typically being a different distance from the listening position compared to the main speakers and the signal chain from the amplifier speaker outlets through a secondary amp circuit as used in an active sub(REL for example).
This is enough of an issue as to be noticeable when listening and gives an impression of "long windidness" to bass notes which start late as a result of the milliseconds delay involved.
Geoff
Posted on: 12 January 2004 by Nime
Any audible delay in response from the subwoofer would indicate too high a roll-off point to match the main speaker's bass roll-off. The subwoofer should never be asked to augment the bass by overlapping for serious music listening. It should merely extend the lower frequency response of the main speakers. Imagine a response graph with another half an inch added to the left of the previous cut-off line.
That Rel should recommend a corner position (to best load the room) may rest entirely on their luxury of having such a low cut-off point available to the demanding listener. Any higher cut-off pount will quickly draw attention to the newly introduced hump in the bass response and "slow" the bass.
My adherence to a close position for the exit ports of my passive Kan matching Subwoofers might well be due to their extended upper response. Though this could be much reduced with a notch filter. Simply spacing the subwoofers another couple of feet apart greatly affected the sound of the system even in a relatively large room. From long experience I can confirm that one cannot simply dump a subwoofer in a room and expect instant success. Any more than finding the perfect spot for the main speakers is a five minute affair.
But if you don't get to play with the toys between listening sessions, then what is there left? Smile
Nime
Thanks for the input though I have to admit you are preaching to the converted. I have a REL QUAKE and have followed the instructions to the letter. My sub currently rolls in at about 26Hz with main speakers rated at -3db at 28Hz, and I have the gain turned down for subtle additional bass which contributes nicely particularly at lower volume listening levels. My comment still applies even with the sub properly tuned in. As with home cinema where individual channels have different delays, bass frequency appear sensitive to this aswell, though not to such a great degree as the mid-range and high frequencies.
It is a "nit picking" thing perhaps since it is hardly noticeable and IS dependent how much really deep bass (down at 20Hz) is present. I get over it within a few minutes of listening so it's no big deal.
regards
GEOFF
Posted on: 12 January 2004 by Greg Beatty
Nime -
"Any more than finding the perfect spot for the main speakers is a five minute affair."
Amen, brother!
- GregB
Insert Witty Signature Line Here
Posted on: 12 January 2004 by Ross1
I had that discussion the other day with my brother re the bass on my system. I have a CDX/CDS/52/Supercap/135's/Nautilus 803 and also a Home Theater system with a subwoofer. He was asking me if I had a loudness button on my Naim system ?? And, after a few hours of listening, told me that he better like the music on the Home Theater with a subwoofer and all the effects ...
My son is 20 years old and would like to have CD's with clips (DVD ??) and be able to look/listen at it on TV (Home Theater) or on the computer with a lot of bass...And, he does not understand why I'm buying CD's.. He says the music should be on DVD's.
Personnally, I can't listen to music for a long period of time on the Home Theater system. No matter if it's CD's or DVD's. I had received the Forty Licks (Stones) and U2 DVD's at Christmas and it's fun to watch in a party but after a period of time, you have to lower the volume. The sub will drive you crazy.
I better like HI-FI with my Naim system with no sub but I think that the trend is definitively on the other side.
Posted on: 13 January 2004 by Arye_Gur
Two of my kids (I have 5) ages 21 (plays a guitar) and 14 who really love music, are saying that the sound of Naim is great. Another son of mine, age 20, who loves to watch movies, says too that the sound of Naim is great for movies too.
Arye
Posted on: 13 January 2004 by Ross1
Arye,
Do you have a Home Theater system ?
When you're saying that your kids are watching movies on your Naim sytem, are you talkng about Naim with AVR (5 speakers + 1 sub) ?
Ciao
Posted on: 13 January 2004 by NB
If you want to listen to real bass then give the Neat ultimatums a try. They work extremely well with Naim gear and the bass has real weight and authority.
With the Neats there is absolutely no need for a subwoofer.
NB
Posted on: 14 January 2004 by Arye_Gur
Ciao,
My kids are not living with me. Most of the music they are listening to is at their homes and at their friends' homes. So they have a base to judge my system.
