Pioneer Elite BD94 blu ray player locks up
Posted by: mikeeschman on 04 June 2009
Is anyone else having this problem? It freezes and has to be unplugged to get it started again.
Have you been able to fix the problem?
Posted on: 04 June 2009 by TomK
Are you running the latest firmware?
Posted on: 04 June 2009 by mikeeschman
i've updated the firmware twice to no apparent effect.
Posted on: 05 June 2009 by bwolke
If you have your player connected to a powerstrip it might be worth a try to re-arrange the power leads. Or put it on its own socket/ powerstrip to see if the problem persists.
