Lingo or Armageddon?
Posted by: count.d on 30 October 2001
What is the best power supply for this set up?
45rpm not needed.
cheers, Martin
Steve
The reports are that the 'geddon serves the flow of the music better; the Lingo is amazing in its bass presentation and other areas which are labelled as 'hifi' by Naim addicts.
I once asked Innovative in Manhattan to demo the 2, and they refused, saying if you like the Naim sound, you'll like the Naim LP12, and so on.
I solved my power supply quandary by buying an ARO - more expensive, but the results were super.
Is it possible for you to hear the 2 in the context of a Naim system?
Tough choice if you have to take it on faith.
Regards.
Phil
PS I have a Lingo because I need 45rpm.
Paul
The Lingo generates it's own mains supply (in effect) that will have less frequency variation than the mains.
Most reviews come to the conclusion that there's not a huge difference between the two, but the reviews have always been with the music-sucking filter in place. The measured results are almost identical, in terms of motor vibrations and spectra.
If you don't need 45, and are buying new the Armageddon is cheaper, although IMO expensive for what it contains.
There is a new Lingo out, I've no idea as to how it compares with the old, but I assume it will still have similar filter arrangements on the mains.
I'm with Steve - buy what's cheapest, old Lingo's are quite inexpensive second hand, and since there have been no major or significant design changes since it's inception (latest version excepted) it will still sound as good as a newer one.
Andy (falling off the fence into the Lingo garden).
I have been unable to find any information on the new Lingo. I will ask my Linn dealer about this "new" Lingo.
Tomorrow I am off to hear, at the invitation of this same dealer, Linn's new flagship speaker - the Komrie(?) - with CD12 and all the other top Linn amps. Should be interesting to hear what Linn is doing (compared to Naim) with what I consider to be very expensive gear.
Last week I listened to Levinson and the new Wilson "Sophias". Very smooth but ultimately too relaxed and uninvolving. The dealer agreed but felt it was the Levinson gear that held the system back, not the speakers. Nonetheless, it was very pleasant to listen to and did a lot of things right to my ears but did not present the "performance" of Naim gear. Critics of Naim would probably claim that Naim gear is "coarse and grainy" compared to the smoothness of Levinson.
Unfortunately, it is not possible to listen to Naim electronics with any of the above as the dealer does not carry Naim and I am not taking my gear across town (as I would have to turn it off!!)
Paul
Has anyone seen the "new" Lingo? Is it possibly the old Lingo in a standard-sized Linn box or completely new?
There was an old lingo in new box, but there is now an updated version that is, I gather, slightly different.
I believe it's just a bit of an update, more surface mount, but nothing major.
Graham's suggest it may be slightly better than an old one, but not significantly.
I asked my local Linn dealer about the new Lingo. He said he had not heard of one but they had not sold any LP12/Lingos recently. He said Linn sold only 400 LP12s world-wide last year and suggested that it may be the final days of the LP12. He still believes that it is a better source than any CD player including the CD12.
As for the Komrie - it was an interesting demo and the full-blown Linn system was very good for the most part but at a very high price (for me). The Komries certainly are revealing and I felt quite involving too (far more so than the Levinson/Wilson system). Perhaps the PRAT of the Linn electronics is not up to Naim standards but the "performance" was there. Considering the price of this system, it ought to be.
Is it bettered by a full blown DBL/500/52/CDS2 system? I really cannot say as I have not heard the DBLs in satisfactory circumstances. However, I have heard and really like the CDS2/52/500/NBLs - one of the best and most musically involving systems that I know. I believe that this Naim system would at least challenge or better the Linn set-up that I heard at a much lower cost.
I am not sure what the Komries would be like with Naim electronics and they might not even work that well as the Komrie has a built in servo amp for the twin bass drivers in each speaker.
Paul
Ade
Why have Linn bothered to do anything with the Lingo at all so late in the day if the LP12's days are numbered.
I guess several reasons: -
1. They need a quality benchmark for developing their other electronics ![]()
2. Some parts may be obsolete in the original Lingo. Mine uses some Zetex devices (as used by Naim) that are now obsolete, other bits may be too. It can be more efficient to redesign than buy large stocks, sitting on your balance sheet.
3. Improvements from new knowledge / devices - see 1 above.
4. Ivor is on record as wanting to be the last TT manufacturer on the planet.
For an expensive and niche product, those sales are pretty good, I'd say. It's not like tooling up for new production, which would make developing an LP12 in the current climate non-sensical.
Andy.
