Paul Lewis Plays Beethoven
Posted by: Todd A on 03 January 2006
A new year means it’s time for some new Beethoven recordings. I thought I’d start small and buy a single disc from one of the several on-going cycles. Paul Lewis is a pianist new to me. I’ve seen his name before, usually in reference to his Schubert recordings, but until now I hadn’t heard him. I’ve read mixed reviews of his Beethoven disc, but irrespective of that I figured it just made sense to give this newish disc a shot. After all, Mr Lewis saw fit to start his cycle with the critical Op 31 triumvirate. This would prove a good test, at least for me: if he botches it, I’m done; if he nails it, I’m hooked. I’m neither.
First the first sonata. If one is interested in hearing what this disc is all about, one need only listen to the first few moments of 31/1. The opening starts with a decidedly middle of the road tempo, and it’s cleanly played and somewhat plain. These are more observations than criticisms, but there it is. Those seeking thrills and gratuitous virtuosic displays, or those looking for heavy-duty heroic period LvB should listen elsewhere. Lewis is one of those pianists who makes the listener come to him. If one does, one notices the subtle rubato and wonderfully controlled dynamic contrasts that mark the sonic landscape. His personal touches are usually not so obtrusive as to distract from the music, nor are they so subtle as to go unnoticed. One touch I don’t care for is the use of overly long pauses at the end of the opening movement. The second movement slows things down just a bit more, and unfortunately Lewis doesn’t sound as good here, at least initially. The long trills aren’t played crisply enough, and the left hand playing is a bit stodgy. As things progress, Lewis improves, and throughout one can detect just a whiff of mischief. It’s subdued, to be sure, but it’s there. Even in the more somber passages. The subsequent reappearances of the opening material become more animated and lively, and the trills pick up in quality, including some beefy low register trills around 9’ in. The final movement opens slower than I generally prefer, but that same almost subversive mischief is still there. Indeed, it’s there throughout the entire movement. It’s as though Lewis is leading the listener on, never quite letting loose, even though the listener knows he wants to, and even though – indeed, most likely because – Lewis knows the listener wants him to. Then, at the end, Lewis lets loose. I suppose one could alternatively hear the playing as somewhat lacking in gravity, but not me.
The Tempest ends up sounding quite similar, and ultimately that dooms it to also-ran status. The problems start in the opening movement. The slightly broad overall tempo doesn’t necessarily hurt, though I can’t say it helps, but what definitely hurts are the muted contrasts. Despite some nice low-end growl, Lewis’ playing ends up making the movement alternate between somewhat soft and sluggish playing and slightly stronger though still somewhat mild playing. Where’s the heat, the bite, the passion? Things definitely pick up near the end of the movement (as does Lewis’ vocal accompaniment), but by then it’s too late. The slow movement ends up, somewhat predictably, sounding better. Lewis again deploys his interpretive tool set deftly, bringing out some nice touches. The final movement picks up where the opener left off, and is noticeably more vigorous than most of the rest of the work. Thundering bass adds to the allure, though this is somewhat offset by some halting arpeggios throughout. Even with a slightly higher musical temperature, the whole thing comes off as just a bit too laid back and soft, but even so is good enough to warrant more listens. It just ain’t a contender for top honors.
The last sonata is the most conventional in approach, and perhaps because of that, it’s the most successful. Overall, Lewis is just a tad bit slower than I generally like, but even with that, everything is well judged overall and the tempi used in one movement or section are well judged when compared to the tempi used elsewhere. Perhaps a little bit of rhythmic drive goes missing – Lewis is certainly no Gulda – but the approach for the whole work is pretty straightforward. Only some slightly sluggish and thick playing just after 5’ mars the first movement. The second movement is nicely entertaining, taken at a nicely brisk clip and possessing solid bass underpinning. The third movement is played well enough, but is too straight. Is the music supposed to be wistful? Defiant? It’s hard to tell. But then Lewis ends things nicely enough. The concluding movement opens with a burst of energy and is superbly played, with superb articulation, wonderfully balanced playing of all the parts, and a supremely well judged overall tempo and dynamics. Had only the rest of the recording been this good this disc would really be something.
But I don’t mean to disparage it too much. This disc is good, it’s just not great. For me, that precludes Lewis’ cycle, whenever it is complete, from being great; if’n the 31s ain’t great, the cycle ain’t great. That doesn’t mean I don’t want to hear more of Lewis’ Beethoven, though. Indeed I do. When compared to Andras Schiff’s and Ikuyo Nakamichi’s openers, I’d say that Lewis is off to a better start, and he may have much to offer going forward. I think Lewis’ playing should work well for the Op 7, 27/1, 28, 54, and 101 sonatas, and so I will wait.
Sound for this nine-month-old recording is very clear and bright with some full, weighty, satisfying bass, though it is more reverberant than I like.
Posted on: 04 January 2006 by Oldnslow
Thanks,Todd. I wondered about the Lewis recording. It is hard these days for anyone to stand up to the Fischer/Gulda standard, that's for sure. If you get the chance I would enjoy your observations about Nicolai Lugansky's recent Beethoven disc (Moonlight, Appassionata, Op 10,no 3, and Op.54). I found it quite enjoyable and unusual, particularly with regard to tempo, but would be interested in your expertise.
Todd, I also have obtained the first two volumes of Ronald Brautigam's sonata series on BIS on fortepiano. I'm not a big advocate of period instrument versions, but I do think his playing in the early sonatas is very fine. His style is direct, forceful, and brisk. I don't know how this series will hold up in the later sonatas, but this is the one current series I will likely obtain as it develops. There is something intriging about trying to envision what the listener might have actually heard back in the time Beethoven wrote these works. We are so used to the modern grand piano that it is a shock to hear pieces so well known on these old (or rather newly created but old style) instruments.
