AV2 - Stereo mode sampling rate ?
Posted by: Roy Donaldson on 16 November 2009
Hi there,
I sometimes run my AV2 in Stereo mode, to allow me to use my subwoofer with music. It is fed this via a stereo source on the normal 2 x phono inputs.
Now that I am using some 24bit 96khz original sources, it would be good to know what rates the AV2 is re-sampling at, so that I am not in fact having the 24 bit sources sampled down when using Stereo mode ?
Thanks,
Roy.
Posted on: 16 November 2009 by rackkit
From the FAQ:
Digital formats supported by AV2:-
PCM:
32kHz
44.1kHz
48kHz
88.2kHz
96kHz
128kHz
DTS/AC3:
no rates over 48Khz are supported
(96/24 DTS audio will be played back, but not at full bandwidth)
This message has been edited. Last edited by: AV@naim, Tue 07 August 2007 10:52
HTH!
Rack.
Posted on: 16 November 2009 by Roy Donaldson
Sorry, not the answer to my question. Those are the samplking rates supported via the Digital Coax/Optical inputs.
The question is via the Analog Stereo inputs, if set to Stereo processing, instead of Direct, what sample rate is used to encode the analog input ?
I remember somewhere that this had changed in the past to fix a Stereo+Sub bug in one of the chips.
Roy.
Posted on: 20 November 2009 by AV@naim
See Here:
Ammended from original vagueness:
http://forums.naim-audio.com/e...2929996/m/3402906017
