72 140 hi connections (sorry!)
Posted by: Martinm on 02 March 2003
I'm being lent a hi cap by my bro to try for a couple of weeks. He powers his CD with it. We can't find the instructions and the lead he has is a five pin. Do I have to find a 4 pin to connect to my system 72/140?
Martin
Martin
Posted on: 02 March 2003 by Tarquin Maynard - Portly
Martin
You can download a connection guide from the main Naim site. If you have problems downloading give me your address via Private Topics and I will post you a photocopy
Mike
Mike
Posted on: 02 March 2003 by Martinm
Thanks Mike,
Will check it out
Martin
Will check it out
Martin
Hmm that has just totally confused me! No pictures of the 72 and the output on the 140 just says pre-amp or power supply?
Anyhow going to run it home and see what i can do with what I've got.
Will be offline till tomorrow night.#
Martin
Martin
Posted on: 02 March 2003 by Dan M
I have a 62/FC/140, but connections should be the same - so from memory I'd say, remove link plug from 5 pin socket. Then, connect 5 pin snaic between 72 and HC, and connect 4 pin snaic between 140 and HC.Power up HC, power up 140.
-Dan
-Dan
Martinm
Oops - sorry!
I do have an OLD setting up guide in the garage somewhere - if the pointers above do not work then let me know etc etc.
Mike
Oops - sorry!
Mike
Martin
Martin
You will not want to see this go - its a great upgrade - do you have spare cash?!
Mike
Have just got in. Thanks guys will try that!
Mike this is what i keep hearing! i think it will help me decide which route to go in the future - upgrade the deck or the CDP!
next weekend will see some further experimentation with the introduction of the cd3.5 -so I could end up a poor man soon! (still the better half just got an engagement ring so I've got a little room for negotiation at the mo
Night all and thanks
Martin
Martin
