vhs -> dvd: no picture on dvd5
Posted by: michael1702 on 12 October 2006
hello,
i captured a vhs video and burned a dvd (as usual) but there is no picture when playing the dvd. just the sound and the naim logo (or a blank screen).
can you see anything in the following mpeg infos which the dvd5 does not like?
thanks a lot,
michael
INFO: [mplex] mplex version 1.6.2 (2.2.3 $Date: 2004/01/13 20:45:26 $)
INFO: [mplex] File ausser_kontrolle.m1a looks like an MPEG Audio stream.
INFO: [mplex] File ausser_kontrolle.m2v looks like an MPEG Video stream.
INFO: [mplex] Video stream 0: profile 8 selected - ignoring non-standard options!
INFO: [mplex] Found 1 audio streams and 1 video streams
INFO: [mplex] Selecting dvdauthor DVD output profile
INFO: [mplex] Multiplexing video program stream!
INFO: [mplex] Scanning for header info: Audio stream c0 (ausser_kontrolle.m1a)
INFO: [mplex] MPEG AUDIO STREAM: c0
INFO: [mplex] Audio version : 1.0
INFO: [mplex] Layer : 2
INFO: [mplex] CRC checksums : no
INFO: [mplex] Bit rate : 49152 bytes/sec (384 kbit/sec)
INFO: [mplex] Frequency : 48000 Hz
INFO: [mplex] Mode : 0 stereo
INFO: [mplex] Mode extension : 0
INFO: [mplex] Copyright bit : 0 no copyright
INFO: [mplex] Original/Copy : 0 copy
INFO: [mplex] Emphasis : 0 none
INFO: [mplex] Scanning for header info: Video stream e0 (ausser_kontrolle.m2v)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 384
INFO: [mplex] Frame height : 280
INFO: [mplex] Aspect ratio : 4:3 display
INFO: [mplex] Picture rate : 25.000 frames/sec
INFO: [mplex] Bit rate : 4000000 bits/sec
INFO: [mplex] Vbv buffer size : 229376 bytes
INFO: [mplex] CSPF : 0
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 4484496
INFO: [mplex] target data-rate specified : 10080000
INFO: [mplex] Setting specified specified data rate: 10080000
INFO: [mplex] Run-in Sectors = 89 Video delay = 13019 Audio delay = 16619
INFO: [mplex] New sequence commences...
INFO: [mplex] Audio c0: buf= 4096 frame=000000 sector=00000000
INFO: [mplex] Video e0: buf= 237568 frame=000000 sector=00000000
INFO: [mplex] Scanned to end AU 157389
INFO: [mplex] STREAM e0 completed @ frame 157389.
INFO: [mplex] STREAM c0 completed @ frame 262316.
INFO: [mplex] Multiplex completion at SCR=566615040.
INFO: [mplex] Audio c0: buf= 1792 frame=262316 sector=00149599
INFO: [mplex] Video e0: buf= 237568 frame=157389 sector=01172437
INFO: [mplex] AUDIO_STATISTICS: c0
INFO: [mplex] Audio stream length 302189184 bytes.
INFO: [mplex] Syncwords : 262317
INFO: [mplex] Frames : 262317 padded
INFO: [mplex] Frames : 0 unpadded
INFO: [mplex] BUFFERING min 15 Buf max 1163
INFO: [mplex] VIDEO_STATISTICS: e0
INFO: [mplex] Video Stream length: 2360757528 bytes
INFO: [mplex] Sequence headers: 13116
INFO: [mplex] Sequence ends : 1
INFO: [mplex] No. Pictures : 157389
INFO: [mplex] No. Groups : 13116
INFO: [mplex] No. I Frames : 13116 avg. size 27696 bytes
INFO: [mplex] No. P Frames : 39348 avg. size 20027 bytes
INFO: [mplex] No. B Frames : 104926 avg. size 11526 bytes
INFO: [mplex] Average bit-rate : 2999600 bits/sec
INFO: [mplex] Peak bit-rate : 5076800 bits/sec
INFO: [mplex] BUFFERING min 15 Buf max 134306
INFO: [mplex] MUX STATUS: no under-runs detected.
STAT: Processing dvd.mpg...
STAT: VOBU 13088 at 2605MB, 1 PGCS
INFO: Video pts = 0.184 .. 6295.784
INFO: Audio[8] pts = 0.184 .. 6295.792
STAT: VOBU 13100 at 2607MB, 1 PGCS
INFO: Generating VTS with the following video attributes:
INFO: MPEG version: mpeg2
INFO: TV standard: pal
INFO: Aspect ratio: 4:3
INFO: Resolution: 704x576
INFO: Audio ch 0 format: mp2/2ch, 48khz 20bps
Posted on: 12 October 2006 by David Dever
More importantly, what is the directory structure of the finalized disc? (This problem comes up quite often, with missing default title sets.)
