next step upgrade
Posted by: fled on 28 July 2003
I need some advice on my next upgrade, although happy with the current set up, I feal that I need more dynamics / drive, PRAT I suppose ?
I can only afford one upgrade £1000 ish.
Current system CD5+Hi 102+Hi+nap 180 Dyn1.1
Q... Should I go for a 2nd hand 82 or 250 what would each give in turn ?
Phil
Posted on: 28 July 2003 by NB
Phil,
You could sell your CD player and put the proceeds together with you £1k towards a second hand CDX!
NB
Posted on: 28 July 2003 by Frank Abela
You'd make life a lot easier for the amplifier if you swapped your Dyn 1.1's for a pair of Dyn s1.4s.
Alternatively look at swapping your CD5/Hicap for a new CDX2. You should be able to do that deal for around £1200 - £1500. The improvement will be remarkable.
Frank.
All opinions are my own and do not reflect the opinion of any organisations I work for, except where this is stated explicitly.
Posted on: 28 July 2003 by Matt worlock
think about selling cd5 plus hicap this should realise approx 1000-1200 pounds, cd5 600-700 hicap 400-500 plus u have your £1000 potentially £2200. Youcould pick up a seconhand 82 for £1150 easy (I know where & who)..leaving ...oh not quite enough for a secondhand CDX but close ..go on take the plunge!! £ I wouls say approx. £1200-1400 is needed for the CDX. Failing this you could just get the 82 and toy around with ehhi's untill you get that CDX!
Mad Boy Matt
Posted on: 28 July 2003 by Nuno Baptista
Sell the CD 5 and Hicap . Go for a CDX S/H
MY system : Naim Nait 5 amplifier,Naim cd 5 ,Epos M 15 speakers,Naca5,FC2
Posted on: 28 July 2003 by prowla
I'm with Nuno, NB, alexgerrard, Frank.
Have a listen to a CDX or CDX2.
FYI, I've got a CDX, but haven't heard a CDX2.
However, a word of warning - some people over on pink fish don't seem to like the CDX.
For me, I think I'll be living with my CDX until I either win the pools or the lottery (and I don't play either, so it'll probably be quite a long time.)
Paul Rowlands
Posted on: 29 July 2003 by David Stewart
Giving due consideration to Frank's first piece of advice -
Maybe you should try to get a pair of 1.4s on home audition before commiting loads of money to a source upgrade, or try a 250 in place of the 180.
Posted on: 29 July 2003 by fled
Thanks all, but with the pending introduction of SACD and /or DVDA I am a little loath to spend on a CD player, although I do agree a CDX brings benifits. So I am realy asking for advice on the merits of 82 or a 250.
Phil
