Is my Headline damaged?
Posted by: mfidelity on 29 December 2003
I just purchased a s/h Headline (olive) + NAPSC PS. I have the Headline connected to the 112 tape socket. At "0" volume I get music from the left channel only - as I increase volume I get music in both channels at it seems to be properly balanced when I reach 12 o'clock on the Headline. After 12 o'clock both channels appear to increase in volume.
Is the unit damaged or is this how a Headline is designed to function?
Thanks,
Dave
Posted on: 29 December 2003 by Manu
It looks like it has a problem. The Volume pot is mistracking. Send it for repair.
Emmanuel
All opinions are my own, and reflect those of the organisation i work for, even if not stipulated.
Posted on: 29 December 2003 by mfidelity
Thanks. It appears to be working fine now that it is warmed up. The unit was pretty cold when I hooked it up. If the problem resurfaces i'll know what I need to do.
Dave
If you mean cold literally: coming from outside "cold and wet", it is quite normal.
What you can do is turning the volume pot up and down many times, it will clean the tracks.
Emmanuel
Posted on: 29 December 2003 by stevebt
Hi, I also have a "pre-used" H/L with exactly the same "problem" I contacted Naim and they said they knew the H/L displayed this charactaristic but it was nothing to worry about. It has been "cured" on the latest one. Also I found that the volume knob was rather wobbly, also a charactaristic apparently.
Still sounds good though!!!
Posted on: 31 December 2003 by mfidelity
The problem is getting worse so it'll have to go to NANA for repair.
Posted on: 01 January 2004 by rch
Oops...
I´ll have to check my Headline immediately!
