Home Built NAS passes Hi-Resolution 4 Room test
Posted by: Aleg on 23 February 2010
Hi
I thought it might be usefull to share some results from the Naim NAS test tool:
I have a home built NAS running Ubuntu Server.
Specifications:
OS: Ubuntu Server 9.10 64-bit
Kernel: 2.6.31-19-server
Motherboard: Gigabyte GA-MA78GM-DS2H (F1 Firmware)
Processor: AMD Athlon(tm) Dual Core Processor 4850e
Memory: 2 GByte
Disks: 4 SATA-300 from Samsung EcoGreen and Western Digital Green
Volumes: 1 combined volume using LVM2 with LUKS Encryption
File System: Ext-4
The NAS test tool was run from a Windows Vista Premium 32-bit Desktop.
All network components are 1 Gbit/s components.
The NAS is Cat-5e cable connected to the same switch as is the desktop and the network router (DLink DIR-855).
It was tested using 4 Rooms, High Resolution for 5 minutes (other settings in default).
The circumstances were less then favourable because I had a large system download running using 40 % of my network bandwidth. But I thought if it passes now then it will certainly do in better circumstances.
The test results were:
Test Run Information:
Name of computer run on: DEVELOPMENT-PC
Date/Time of start of test: 24-2-2010 7:18:07
Network share that test was applied to: \\UBUSRV\Videos
Period that test ran for: 00:00:18:12
Time taken to write the test files to NAS drive: 00:00:12:56
Time taken to remove the test files from the NAS drive: 00:00:00:06
Options:
TotalRoomsPlayingAtOnce: 4
Audiotype: HighDefinition
Period: Five_Minutes
SimulateBackgroundMusicRescan: True
RescanThrottle (ms): 0
SimulateRandomPlayback: True
TotalArtists: 4
TotalAlbumsPerArtist: 5
Results:
Result:
Name: Initial Connect Time
Measured: 1029
Threshold: < 5000 ms
PassFail: Pass
Result:
Name: Average Write Throughput
Measured: 12,35
Threshold: > 2 Mbyte / sec
PassFail: Pass
Result:
Name: Average Read Response Time
Measured: 5,61
Threshold: < 25 ms
PassFail: Pass
Result:
Name: Max Read Response Time
Measured: 431
Threshold: < 500 ms
PassFail: Pass
Result:
Name: Total Audio Breakups
Measured: 0
Threshold: = 0
PassFail: Pass
Result:
Name: File Scanning Performance
Measured: 81,26
Threshold: > 10 per second
PassFail: Pass
Result:
Measured:
Threshold:
PassFail: Pass
Underflow errors:
aleg
Posted on: 24 February 2010 by DaveBk
I've also run the test against my Buffalo Terastation Pro:
Name of computer run on: XTREME
Date/Time of start of test: 24/02/2010 11:01:41
Network share that test was applied to: P:\
Period that test ran for: 00:01:17:45
Time taken to write the test files to NAS drive: 00:01:02:39
Time taken to remove the test files from the NAS drive: 00:00:00:03
Options:
Period: Fifteen_Minutes
TotalArtists: 4
Results:
Result:
Measured: 37
PassFail: Pass
Result:
Measured: 2.55
PassFail: Pass
Result:
Measured: 14.10
Threshold: < 25 ms
PassFail: Pass
Result:
Measured: 102
Threshold: < 500 ms
PassFail: Pass
Result:
Measured: 0
Threshold: = 0
PassFail: Pass
Result:
Measured: 39.80
PassFail: Pass
Result:
Measured:
Threshold:
PassFail: Pass
Posted on: 24 February 2010 by David Dever
One thing worth pointing out from previous qualifications–it is well-worth running the test for a 24-hour period, as this will catch any energy-management or time-related QoS glitches that might arise during the lengthened qualification testing process.
