Cats and speaker grilles (not grilled cats)
Posted by: Eric Barry on 07 December 2002
I love my cat, and my cat loves to eat the foam grilles on my Linn Isobariks and sit on the top (where there are two drivers under the grille).
I have heard tell of things you can put on speaker grilles that won't harm any person or feline but will discourage ripping and sitting. Anyone?
--Eric
--Eric
Posted on: 07 December 2002 by Roy T
A few drops of tiger urine (small drops as this is high octane stuff) do the job or so I have been told.
Posted on: 07 December 2002 by garyi
ram your foot up its arse and use it as a slipper.
I hate cats.
I hate cats.
Posted on: 07 December 2002 by Bob Shedlock
From one with two cats - The easiest thing is to cover them when not in use. Most felines detest plastic, so a plastic wrap for lunches works fine.
There are also sprays that can be applied to the grill, or small patch of cloth and then set on a piece of plastic. These are tremendously effective, even at keeping the feline demons from the christmas tree. Downside is they need to be refreshed every couple of days.
Last but not least, give them at least one tablespoon of catnip each week. Tends to reduce or eliminate the chewing tendency
Posted on: 07 December 2002 by Nime
Hi,
My wife (who is besotted with cats) suggests:
a.Try feeding the cat now and then.(hungry?)**
b.Buy a sub-woofer! (sorry, she said it, not me)*
c.Attach velcro dots and park cat somewhere.(?)**
d.Buy a Coleous canina plant or two. Place near speakers. Cats hate it.****
e.Apply orange and/or lemon peel to prohibited areas.***
f.Try some lions dung from the zoo. (I have to believe this is an outdoor treatment!)
g.Get cat a scratching post.*
h.Buy (or borrow) a fearless dog and keep it in
listening room when not in use. (May damage things itself when bored. Not recommended)
i.Apply sudden short burst of loud music when cat is lounging on speaker.(Shania Twain?)*****
I accept no responsibility for any of these suggestions.(Our cat is now very well behaved) Though we used to put cardboard, magazine racks or plywood in front of the speakers when it was younger to avoid him climbing the grills. He doesn't like loud music. Perhaps I just haven't found something to his taste yet...
Nime
Nime
Posted on: 07 December 2002 by AL4N
Cut off all of it's feet,and then nail it to the floor.
Posted on: 07 December 2002 by quickie
I hate cats.
You forgot to cut it's legs off!
Posted on: 07 December 2002 by Martin Clark
Try using a lemon - most cats hate the smell and will avoid. Slash the rind and wipe the oil on the cabinet.
Failing that try biwiring the cat.
Posted on: 07 December 2002 by gusi
I had the same problem with my cats and briks.
I now put some wooden planks on the briks when I am not playing any music. My cats don't like to sit on the wood and don't dare climbing on the briks when I am there listening to the stereo.
Even if they do jump on there is nothing to scratch and their weight is carried by the box and not the drivers.
You could use some serving trays for higher waf.
cheers
Gus
PS playing a loop of vacuum cleaner noises should also do the trick (the real hooversonic) but I'd try the planks first.
cheers
Gus
Posted on: 08 December 2002 by NB
I find that a quick blast from a water pistol tells a cat that their behaviour is not acceptable!! and they soon learn not to do it.
Just be careful that you don't get too much water on your barik's they dont like it.
If not there is always the petrol and match soloution
NB
NB
Posted on: 08 December 2002 by Roy T
I think you will find that is for hot dogs. . .
Posted on: 08 December 2002 by Martin Clark
Not quite; petrol and matches skilfully applied can indeed make a cat go 'woof'.
M.
M.
Posted on: 08 December 2002 by Eric Barry
My cat is not hungry (maybe lonely and bored). She doesn't eat the foam really, just shreds it. She used to shred newspaper the same way. The spray won't work because I am around to yell at her when I'm home--the problems are when I'm at work. In fact I have never seen her on the Briks, just the impression from her body and the shredded foam. Too lazy to place and remove planks multiple times per day. My cat likes to sit on plastic shopping bags, so I don't think plastic is the solution. She also handles loud music fine.
--Eri
--Eri
Posted on: 08 December 2002 by Bob Shedlock
Shopping bags are not the same as saran wrap, but, like trays, you'd have to put it on and take it off
Posted on: 08 December 2002 by gusi
If your cat only misbehaves when you at work the trays won't be such a hassle. I always put a CD on and then take the planks off.It takes about one second. Then I put them back on when I go to bed or leave the house.
You could experiment with some chopping/cutting boards from the kitchen. Once you stop finding cat hair on them you can probably stop using them.
It'd be a shame to loose a tweeter to the cat.
cheers
Gus
cheers
Gus
