Expressimo widget for Rega RBx00 arms
Posted by: Joe Petrik on 06 September 2001
A couple of weeks ago I got one of these:
To try on one of these:
Mainly because it looks so much neater than one of these:
Although initially skeptical of the somewhat over-the-top claims by the manufacturer, I'm convinced that the Expressimo "Heavy Weight" counterweight is a good thing -- in the context of my system and given my priorites.
The first thing I noticed was that needle noise virtually vanished. The stylus was in the groove and the platter was turning but I couldn't hear any surface noise. Yeah, the volume knob wasn't pegged but whatever surface noise I usually have with stock Rega weight was that much lower with the HW.
My cartridge (an XX-1L) also tracks substantially better with the HW, even though tracking is one of its strong suits. On heavily modulated stuff -- whether insane bass on drum 'n' bass 45-RPM LPs or orchestral finales -- the stylus tracked the groove just that much better, leading to a smoother and more refined presentation. Normally, "smoother and more refined" is code for "boring" but in this case it was more like the way an Ekos is more refined than an Ittok.
The HW also does stuff to the soundstage and image but I really don't care about that. Suffice it to say that the presentation got "bigger".
None of this would matter, of course, if the HW killed the music. For me, in my system, it most definitely does not. The separate instrumental lines become easier to follow, the bass is tighter and more controlled, the mids and highs are cleaner, dynamics have more kick, and the music is more coherent.
At first I mistook the smoother presentation of the HW as being less fun. But after living with the HW for a couple of weeks it's clear that the "excitement" of the stock weight (probably caused by slight mistracking with the stock weight) is falsely adding to the mix. It's a lot like the way that with a quick A/B an Asaka can sound more impressive than a Troika. But listen over time and it becomes patently obvious that the Troika is the better, more accurate cartridge.
Maybe you'll love the HW, maybe you won't but it's an easily reversible tweak (just take it off and put the stock weight back on) and the manufacturer does have a money-back policy if you're not happy. So, if you don't like it you're out only the cost of shipping to and fro.
Definitely worth a try on an RBx00.
Joe
P.S. The HW has a set screw to keep it from sliding off the arm. I experimented with different levels of torque, from just tight enough to keep the HW from falling off, to finger tight plus a tiny nip, to finger tight plus a bit more of a nip. I definitely prefer it firmly attached to the arm but I would caution obsessive tweakers to not overtighten the screw. It could damage the arm, bearings or both.
Posted on: 06 September 2001 by Eric Barry
Anyone compared? You can put the Heavyweight on a OL'ed Rega. But the OL mod changes the stub, not just the counterweight.
--Eric
Posted on: 06 September 2001 by Tony L
Me too, me like. Not as important as having a phono stage though, I really must get one…
Tony.
Posted on: 07 September 2001 by Joe Petrik
(I am) Simon,
Would such a weight fit on my old rega s shaped silver arm
Dunno. Why don't you e-mail da man for an answer? He's at sal@foggy.net.
Joe
Posted on: 07 September 2001 by Dev B
The UK branch of Mullet Audio is in London, England (my place) and the North American branch is in London, Canada (his place).
We are both delighted to receive visitors and preach our wisdom.
email me for details.
DVD/Mullet Audio
Posted on: 25 October 2001 by Chris L
A couple of quick questions about the HeavyWeight:
First: it looks, from Joe's picture, like there's a protective sleeve between the weight and the arm stub, presumably to stop the grub screw damaging the arm and to spread the load a bit. Can either of you confirm that there is/isn't?
Second: Is there somewhere in the UK selling these at a sensible price, or is it still better to order from somewhere in the States? Better from the manufacturer or a retailer?
Thanks,
Chris L
Posted on: 25 October 2001 by Tony L
Yes there is something like that. Its very well made, and fits very accurately. Its also available in different weights, so get the right one for your cart. I have the heaviest 130g one which balances my 10.5g Ortofon MC25FL nicely.
Buy from the US, UK importers take the piss completely and charge at least a 1 to 1 USD to UKP rate. www.mailordercentral.com/elusivedisc do 'em for 79USD. If its all too much hassle I'll swap mine for your Burns Marvin, I'll even pay the postage....
Tony.
A generous offer, Tony, but I think I'll just order it from the states - even though I'll have to pay the postage!
Pity about the timing, though, with the whole anthrax thing, it'll probably take even longer than usual.
Chris L
Posted on: 25 October 2001 by dave simpson
... might remember when the original Ittok's counterweight was two piece. A small add-on ring held by an allen screw to balance heavier than normal cartridges of the day. I recall shortly after the Ittok's introduction our monthly service bulletins advised us to use the add-on rings whenever possible ...period. They (Linn) found the additional mass required the counterweight be brought in closer to the bearing assembly when dynamically balancing the arm and therefore offer better performance (can't remember the science...old fart's memory and all).
Regardless, I say we make Petrik head of Linn R&D...first product - The Petrok VV unArm.... HEY!... it stops that "K" naming thing....ok?
dave
