unity gain query
Posted by: Mario on 10 November 2003
Hello all,
After a couple of weeks with the new 282/250 things are getting pretty good, even though the initial warm-up period had me worried. Anyway I dont have any av equipment connected to the 282 but wanted to access the unity gain function to check it. After selecting AV and putting the pre into program mode, I hit the source mute buttion twice and then backed out of program mode. Things appear to be working ok as the lights on the volume and balance were no longer lit up. The problem was when I took the source mute off and heard a loud hum through the speakers. Does anyone know what is going on here? Does there have to be something connected to the AV input for the unity gain to work quietly? I don't recall having this problem with the 112 although I can't really remember if I checked it. I'm assuming that when unity gain is used, the source mute button is not lit up.
Regards Mario.
Regards Mario.
