phono----nac102
Posted by: Charlezz on 08 January 2002
I have an old phono player(?) and i would like to connect it to my Nac102.
What do i need???
Charles
You'll also need to attach the BNC connectors that came with your 102. Alternatively, you can just get some RCA>BNC adapters. Naturally, the former option sounds better.
Look inside the din closest to the BNCs has some subtle lines indicating if its connnected for din or BNC
How can I know that?
Charles
ps: How much do phonocards cost?
They are about £90 for a pair.
If you are on about the cartridge, post the name I am sure someone will know what it is.
If you already have cards in the 102 then they will be visable on the left hand side where the BNC input is, they are about 2 inchs by 3 inches and sit above the main board, one for each channel
If not then you will see the main board with four gold coloured points and a white peice of plastic each for each channel, waiting for the appropriate boards.
I have bought BNC-RCA adapters to connect it.
Do i need MM or MC cards??
Charles
If the cartridge is the original, it's almost certainly MM.
Best Regards,
Mark Dunnn
