how noisy should an n-vi be?
Posted by: gloop on 24 September 2007
hi. recently set my n-vi up and all is quiet for the first few minutes, but sooner or later then fan kicks speeds up and it, together with a loud tick / clicking noise can be heard across the room and over quiet music or dialogue.
how much noise is normal?? thanks all.
Posted on: 24 September 2007 by Former member
There should not be a ticking sound.
The fan should only come on when very warm.
Do you have enough space around and at the back of the n/vi?
Posted on: 25 September 2007 by Mike1380
Even when the fan's running on mine it isn't audible... can only hear the fan by being behind it, certainly not from my listening position 8 feet away from the n-Vi.
Posted on: 25 September 2007 by AV@naim
What firmware are you running?
http://forums.naim-audio.com/eve/forums/a/tpc/f/3452929996/m/3592918807
see above link on how to get firmware revision
