My broadbands knackered!
Posted by: garyi on 17 March 2005
I have been having significant broadband problems. Over the past few days it has been appaulingly slow but still kind of works. I think I got it down to the fact I can send out at the normal speed but incoming was down to around 50k.
Today the speed is back to normal but if I don't use the connection for ten minutes I get cut off.
I phoned Metronet who confirmed and said that it could only be a hardware problem with the router or filter, that is causing the my computer to get out of sync with their end???
Thing is how the hell can I check? I have swapped out the microfilter for another and the router is a ZOOM that has only been going a few months, and seems OK, the lights light up and I get connection OK.
If I lose connection all I do is swich the router off then back on, after a while my connection comes on. If I use the connection all the time, such as surfing downloading etc then its fine, if I leave it for ten minutes then bam, I loose connection!
What else can I check? I think I lost the recipt for the zoom box doh!
