N-vi Display
Posted by: john R1 on 14 March 2010
Any ideas why the display on my N-vi keeps coming on for no reason, or this just another fault to put on the list of failures with them
Posted on: 16 March 2010 by garyi
I get this from spurious infrared when doing other things like changing channels.
Posted on: 16 March 2010 by james n
Same here - just would see a (non n-Vi) command, trigger the display to wake up for a while and then go back to sleep. Well it did until the display failed (now back at HQ for a new one)
James
Posted on: 29 March 2010 by AV@naim
Is this on DVD or CD?
Is this on a chapter/track change?
Or is this just when sat idle (on what input)?
Posted on: 29 March 2010 by David Dever
If the surround bitstream mode changes (e.g., when transitioning from TV program in 5.1 to an advert in Dolby Digital 2.0), and the display setting is set to "off" from the remote, then the display should chime in with the appropriate mode displayed.
Posted on: 29 March 2010 by james n
These failing displays seem to be becoming more common place. Is there a reason for the failures?
I'm not sure if Naim are using a different model. Mine has always looked a bit 'rough' - when i saw one at a dealer a while back it was a much nicer display. Mine slowly lost brightness and then dissapeared. N-Vi was always used display off but i was a bit dissapointed it didnt last longger. Reminds me that i should find out when it'll be back...
James
Posted on: 04 April 2010 by john R1
Thanks for the replys, it was when i had played a cd then switched over to cable, now seems to be working ok again ?
Posted on: 07 April 2010 by AV@naim
If the display was off and you changed input, I would expect the display to come on, to tell the end user what input it was on - or am I not understanding here?
Posted on: 22 April 2010 by john R1
AV@Naim i would also expect the display to come on as you described, but not to keep coming back on when turned off, but as i said now seems ok
