AV connected TV sounding through all other preamp inputs
Posted by: JonnyC on 21 September 2009
Dear All,
When I connect my Sony TV to my nac 112x via the AV input I can hear the tele through all other preamp inputs except the AV input.
Am I doing something wrong (over and above connecting a cheap TV to my naim through a Maplin cable) or has the preamp got fried circuits? When I disconnect the TV all is fine.
I understand one has to be careful of earthing loops. The TV is supplied through the ring main and the Naim through a separate spur.
Any thoughts would be greatly appreciated,
JonnyC
Posted on: 25 September 2009 by winkyincanada
Looking at the maunal for the 112 (couldn't find the 112X) it says that the "mono" button on the remote operates the tape monitor circuit. This might be mixing things up. I would try toggling that.
Anyone know how to do a full reset on a 112X? I coudn't find it.
Posted on: 30 September 2009 by JonnyC
Hi Winkyincanada
Many thanks for the suggestion but unfortunately it hasn't worked. Tried the factory reset as well (hold down disp key in programme mode) but no joy.
Posted on: 02 October 2009 by garyi
Try adding it to say the CD input and see if the problem persists.
Posted on: 02 October 2009 by Richard Dane
Jonny,
this sounds like the cheap Maplin cable has got a DIN that isn't correctly wired for Naim. What you describe is symptomatic of putting a signal input through the tape loop outputs - you end up with signal on all inputs!
I'd get an interconnect specifically made for Naim DIN.
Posted on: 15 December 2009 by JonnyC
ecifical
Sounds like a very good idea Richard.
Thanks for all your reponses
