NVi Remote Control
Posted by: RobinS on 13 November 2007
I have recently installed an NVi with DAB and all is just fine - but the remote seems a little unpredictable! I have found the instructions for resetting it, but with DAB it still does not seem to perform as per the manual
1. Using the numeric keys with the NVi in DAB preset mode does not select preset stations. It has no effect
2. Using the up/down, left/right keys in DAB mode changes the Input (to FM, CD etc) or changes the Decode Mode. It does not scroll through stations or station information as per the manual(E21).
As an ex-IT person I can work most things out but this has got me stuck. Any suggestions please?
Robin Stafford
Posted on: 13 November 2007 by David Dever
Press the "dvd" modal button to properly access the tuner features.
Posted on: 13 November 2007 by AV@naim
As its an intergrated AV pre-amp and DVD player, you must switch between the AV and DVD buttons on the remote to access certain functions.
See part 6.2 of the manual...
Posted on: 16 November 2007 by garyi
God anyone knows if you want tuner you have to press DVD.
Der!
