Helikan
Posted by: Christopher on 27 May 2003
Hi everybody
Would it be worth running a Lyra Helikan through a naim phono card (in an 82), or is this severely limiting its performance?
Rest of equipment is LP12, Aro.
Currently only have an MM card, so would need to change this (how much are these nowadays?). Ultimate aim is prefix, but won't be for 6 mths or so...
Thanks!
Posted on: 27 May 2003 by Frank Abela
The Naim boards are excellent value for money at around £95/pair. They won't elicit every last nuance of music out of the cartridge, but they will do a good job nonetheless until you decide to upgrade the phono stage section of your amplifier.
Frank.
All opinions are my own and do not reflect the opinion of any organisations I work for, except where this is stated explicitly.
Posted on: 27 May 2003 by Chris Bell
Christopher,
What you want is the Helikon SL, which was designed with the Naim K phono board in mind.
It is a supurb cartridge, made even better by the use of a prefix. Adding a supercap to the prefix takes performance into a realm I did not think extisted.
Hey this is my 200th post!
Chris Bell
Posted on: 28 May 2003 by Laurie Saunders
The Helikon works fine into Naim K boards.
Laurie S
