Best slimline pocket camera
Posted by: perflemming on 29 November 2008
Would I be looking for Pentax, Casio, Nikon or...?
$200-$300
little thickness and simple function matters + good pictures offcourse
I have no problem with last years model
thanks
Posted on: 30 November 2008 by u5227470736789454
Panasonic lumix fx 150 if you want a really pocketable camera with some decent manual controls ( I have one and it is a great supplement to my digital SLR
Check out dpreview on the web it has a good set of reviews and some very informative forums
A ggo rule of thumb is if it feels right and usable then you are more likely to carry it and use it.
Good luck and use/enjoy whatever you buy
Posted on: 30 November 2008 by BigH47
There were some good value deals on Panasonic TZ3 after the new TZ5 came out, not sure if they are still about. It's not a super small camera but very well made and equipped. C £140.
Posted on: 01 December 2008 by Kevin-W
You can pick up a Leica C-Lux 2 cheaply at the moment (the new C-Lux 3 is out).
I have one, it's a gorgeous little thing which feels great, has all the features you need in a compact and, most importantly, takes superb pictures.
Posted on: 02 December 2008 by nap-ster
I have a Lumix FX500. Great photos plus it has a very wide angle at the bottom end of the zoom.
