Programmable remotes...
Posted by: ntom on 02 May 2003
I see there have been quite a few threads discussing the merits of programmable remotes. I have a Pronto & it works well. Have it controlling my 82 + CD, CD-R, DVD, VCR, TV etc. However, I have two oldish cassette decks Nakamichi CR7 & Revox B215, & a Revox tuner, but.... dont have a remote for these. Found codes on remotecentral for the tuner. can't find any for the cassette decks... Both are remote controllable so... any audiophiles amongst you who have either of these decks & use PRONTO (or equivalent), who could send CCF files or just the hex codes...?
Posted on: 02 May 2003 by Greg Beatty
If you have a One-For-All remote, you can do a manual code search. This involves entering successive three or four-digit codes and trying commands as you go.
Its not as bad as it sounds - I spent one evening mapping out a Yamaha surround sound receiver once. Got all of the surround modes etc.
Once you have them figured out on the One-For-All you can 'learn' them to the Pronto.
That's how I would do it. Anyone else?
- GregB
Insert Witty Signature Line Here
Posted on: 04 May 2003 by ntom
....but that means getting up.... Confused
she bought me the Pronto....!!!!
(...& i'm after some more Naim kit so I daren't...)
