Lip-synch
Posted by: Rockingdoc on 21 October 2009
Using a Samsung 7000 TV with a Samsung BluRay player and Virgin cable,all HDMI connected. Audio output via optical socket on TV or on BDP to external DAC, then DAC analogue outs to hifi.
Lip-sync for audio from the DAC is poor for TV or BD. Is there anyway to manually alter lip-sync? Is the only solution to get an HDMI receiver and use analogue audio outputs from that, and is it guaranteed to sync?
Posted on: 21 October 2009 by james n
Have you had problems all the time with Virgin. Just asking as for the last two weeks we've had quite a lot of problems on the TV side (V+ with an n-Vi doing the TV sound) ?
James
Posted on: 21 October 2009 by Former member
The older virgin boxes of this world have a lot to answer for.
Thanks for nothing. Winker
Whats Lip -synch? Winker
Posted on: 22 October 2009 by Rockingdoc
I'm still trying to understand it all. For years I have just used an analogue audio-out from the TV which had an analogue feed via SCART from the Virgin box. My new TV takes a digital feed (HDMI) and has no analogue audio-out.
Obviously the lip-synchronisation problems must be caused by differing delays in processing the digital signal by different components. I was hoping there might be some hidden menu somewhere that allowed the audio delay to be adjusted to match the visuals.
p.s. HMV added a load of BluRay discs to their sale yesterday, all priced at a fiver. I happened to be in the store as they were being priced-up, so got first go. I bought 12 really good films on BD for 60 quid.
Posted on: 23 October 2009 by Occean
I know deep in the menus of my sky hd box I can adjust the audio delay, not sure about the virgin box though.
Posted on: 23 October 2009 by winkyincanada
A virgin box with proper lip-synch isn't to be sneezed at.
Posted on: 15 November 2009 by likesmusic
A company called Felston make a relatively (for NAIM users) inexpensive remote controlled digital-delay box called a DD740 to sort lip-sync problems. Keene electronics sell them in the UK.
