Google
Posted by: ErikL on 29 December 2003
I like Google. I use Google Search (regular, image, etc), Froogle, and Google News a lot. I also use the Google Toolbar with built-in popup blocker.
Today I came across this. Neat features and services I hadn't discovered! The coolest find there is Google Labs which gives you a glimpse into Google's dev group and its projects. Besides being cool, it's smart business (the site allows you to provide feedback on alphas/betas, and to discuss them with others).
[EDIT: And now I found this! I didn't know about the define and calculator functions.]
Ludwig, Integrated New Product Development fanatic
[This message was edited by Ludwig on TUESDAY 30 December 2003 at 01:07.]
Posted on: 29 December 2003 by matthewr
You might want to try the Google Deskbar which is great (once you get yourself trained to use it).
Matthew
Posted on: 29 December 2003 by ErikL
The deskbar looks interesting. I could lose the browser toolbar, install that, and then install a popup blocker.
Do you know of any good, free popup blockers? Smile
Posted on: 29 December 2003 by Dan M
Ludders,
If you like google check out the "I'm feeling lucky thread" below. Also, try it on "miserable failure."
cheers,
Dan
"Do you know of any good, free popup blockers?"
Mozzilla Firebird Wink
Posted on: 29 December 2003 by Former member
Mozilla Firebird also has integrated Google searches without modification.
Try it, and I'll bet you won't go back to Internet Exploder...
http://www.mozilla.org/products/firebird/
Graham
Posted on: 29 December 2003 by Jez Quigley
Whilst you are at it, try www.ungoogle.com as well
"Be my lover, don't cause me pain, just play me John Coltrane"
Posted on: 31 December 2003 by Rasher
The deskbar is brilliant. Thanks for that.
