I've lost all the icons here.
Posted by: BigH47 on 29 June 2007
I was editing a post and may have hit the ctrl and something becouse the screen flashed and all the icons have now disappeared. I have restarted PC but it's still the same.
I still have the buttons they press and contents show eg text to colour, url etc.
I'm using Mozilla. It's is similar on I.E.
Any ideas ?
Howard
Posted on: 29 June 2007 by BigH47
As you may spot I can't edit my second post with the quotes it just enters another post.
Whoops wrong button.
Posted on: 29 June 2007 by Sloop John B
Howard,
It may be the Gigondas but I have no idea what you are on about.
But Happy Christmas anyway
SJB
Posted on: 29 June 2007 by Ian G.
SJB
Are you going to sleep at all tonight John ??
Ian
I suppose I really should.
Good Night Ian.
SJB
trouble is, once you get those speakers you really like you get trapped playing LP after LP....like wot is happening here.
Ian
I 'll try explaining again. If you open the reply or edit window. You get light blue boxes with little pictures in except I dont get the pictures any more I also don't see smilies. As I said before the buttons are there and operate but with no pictures(icons).
Posted on: 30 June 2007 by garyi
Oh dear, perhaps someone stole them?
Posted on: 30 June 2007 by Adam Meredith
So - it's not all bad?
Posted on: 30 June 2007 by Sloop John B
Ian
I certainly hope so.
SJBPosted on: 30 June 2007 by Sloop John B
Howard,
Is it only on the naim forum this happens. If you go to the main naim site does it load normally?
And can you see smilies in posts
SJBPosted on: 30 June 2007 by BigH47
OK so I right clicked where one of the images should be. An option "block images from forums.naim-audio.....". I deselected it and presto images back.Not only this site but the other site too.
Hey whatever works eh!
Howard
