Speedy Service – Thanks!
Posted by: Hammerhead on 04 June 2003
Just a quick thank you to the ladies and gentlemen in Naim’s service department for a very quick turnaround on my Hi-cap service & re-cap. I dropped it into Naim HQ last Wednesday and it arrived back home at 1pm today! Now plugged in and strutting its stuff.
Steve
Posted on: 04 June 2003 by Timbo
Agree - Naim's service dept is probably the best on the planet.
Tim
Posted on: 04 June 2003 by ARC
Had a 52 re-capped in 10 days - excellent turnaround. I have to say that I'm a massive fan of secondhand Naim kit mainly because of the quality of support that you get. I've no idea if servicing works out cheap or expensive in monetary terms at Naim but I just don't care, the level of service is worth its weight in gold.
Brendan
AllenB,
I was also told 3 weeks, it just happend quicker.
Brendan
Posted on: 05 June 2003 by Jonathan
Does anyone know if unity gain is available for 82? It would certainly encourage my decision to go for and AV2 and 175
Posted on: 05 June 2003 by Kevin-W
Sorry, can I show my ignorance here?
What is unity gain?
Kevin
Posted on: 05 June 2003 by Maxi Me
It turns your preamp into a very expensive switch. (to quote a hi-fi mag)
Basically it allows an AV amp to bypass the preamp volume control and drive the power stage directly. The upshot is that you don't need to juggle two volume controls every time you switch to the TV/Video/DVD
Seth
Is Naim the only way forward?
Ahh, Ahh! I'm burning!!
