Component Cable lengtht
Posted by: Jerryl on 19 September 2005
I will be reorganizing my room and will need to run a lengthy Component Cable from my Satellite receiver to Hitachi Plasma, my estimated length is approximately 8 meters. Will I loose quality because of the length?
Jerry
Posted on: 19 September 2005 by Mr Perceptive
Not with a good quality cable. 75ohm video signals are specc'ed to run 75m (I used to work on the fringes Broadcast TV), you can run them further but you need to apply a line driver and some form of equalisation at the other end.
The quality of cable really counts though, you should be using decent screened cables, with seperate cables for R, G and B, not some thin bundled jobby.
Hope that helps
Mr Perceptive
Posted on: 19 September 2005 by arf005
Should be cool Jerry, so long as you use quality cable as Mr P suggests...
Not quite the same but we've ran s-video for over 10m behind the walls in our Den and there is no visible loss of picture quality....
Go for it!
Ali
Posted on: 20 September 2005 by HiDefBob
I am running a 6 meter component cable out of a component switcher (3 in 1 out) in my system with no problems ... PQ is excellent.
Posted on: 25 September 2005 by Jerryl
thank you all for your help,
Jerry
