NACA5 Question
Posted by: Chris L on 01 February 2002
On the the recent "Help - no sound" thread the follwing was mentioned:
Each speaker cable housing has a "POS" mark on it, and this should be to the red/positive input
Well, I have to say, if that relates to A5, it's a new one on me. The only marking I can see is the directional marking.
So, can anyone enlighten me?
Ta,
Chris L
Posted on: 01 February 2002 by Frank Abela
There are lugs on the Naim SA8 connector. Two lugs on one side and one larger lug on the other side. The larger lug has POS written on it.
The lugs are designed such that they will foul if you try to connect them up to a stereo Naim power amp the wrong way round.
Frank.
All opinions are my own and do not reflect the opinion of any organisations I work for, except where this is stated explicitly.
Posted on: 01 February 2002 by Chris L
Thanks Frank. That does explain somewhat my confusion, as I've only got Naim bananas at the amp end, the speaker, and more easily accessible end, is bare wire into the binding post.
Chris L
Posted on: 01 February 2002 by Manu
_
What do you mean?
Nothing like that, it is not foul-proof. It fits either way.
Emmanuel
