Recovering deleted files
Posted by: JamieWednesday on 20 February 2008
Folks, can anyone recommend some decent software they use for the above - there are a few on the web but the trial versions I've seen don't actually let you recover files so I can't check how effective they are and I don't want to shell out for some pony...
Posted on: 20 February 2008 by djftw
I've used various things, but never been very happy with the result, pictures with changed dimensions, music files with clicks, pops or just silence, documents with huge gaps, or bits of other documents, or sometime just complete gibberish! You might want to see what PC WORLD charge, as I seem to remember that they off such a service and at least if it doesn't work you have someone to complain to!!!
Posted on: 20 February 2008 by NeilM
I used the free offering from http://www.softperfect.com/
I only needed to use it once and as far as I can remember it did the job I asked of it
Neil
Neil
Posted on: 20 February 2008 by BigH47
quote:You might want to see what PC WORLD charge, as I seem to remember that they off such a service and at least if it doesn't work you have someone to complain to!!!
They are the ones that lost my files.
Posted on: 20 February 2008 by AV@naim
http://www.recuva.com/
-always backup critical files
-if you have a major failure/data loss, don't boot the OS drive. put it in another PC as a slave and use the recovery utility from the PC. Windows has a habit of overwriting once-used sectors.
Posted on: 21 February 2008 by djftw
quote:Originally posted by BigH47:quote:You might want to see what PC WORLD charge, as I seem to remember that they off such a service and at least if it doesn't work you have someone to complain to!!!
All the more reason to get them to sort it out! Demand they do it for free and compensate you!
Posted on: 21 February 2008 by Phil Cork
Similar answer to the one i gave on the restoring photos thread:
I would try and avoid saving anything to the affected drive until you attempt to restore the files, as once you write over the space the files occupied you'll have almost certainly lost them.
I'm not sure how Windows uses swapspace, ie a dedicated contiguous area of drive, or random areas of drive, so it may even be best not to use the machine at all for fear of the files being overwritten.
Someone who knows more than i do about how this works may be able to provide more detail...
Good luck.
Phil
ps anyone remember 'undelete' on Dos 5/6?
Good luck.
Phil
Posted on: 21 February 2008 by JamieWednesday
Winundelete is available but on trial version it can't actually 'restore' the file so I can't tell how efefctive it is and I hate wasting money on software that turns out to be sh*t - as so much is...
I'll try a couple of the freeware options
Thanks all
Thanks all
Posted on: 21 February 2008 by Roy T
quote:-if you have a major failure/data loss, don't boot the OS drive. put it in another PC as a slave and use the recovery utility from the PC. Windows has a habit of overwriting once-used sectors.
If you can get a copy of a Knoppix live cd or something like it via another machine you may well then be able to boot into the offending machine with the live cd and save a few files. All done with the aid of free and open source software.
Machine is fine, I just want to recover a file I deleted
Posted on: 21 February 2008 by Diccus62
Neil
Seems to be working so far -
Thanks y'all
DimDiccus
Posted on: 22 February 2008 by Blueknowz
There is also a Free Download from Computer Active in the latest edition File recover
Posted on: 22 February 2008 by Analogue
Jamie are using a PC?
If so try systems restore.
Hope this helps
Chris N
Posted on: 23 February 2008 by Jim Lawson
System restore refers to registry. It will not recover files or documents so don't bother going down that road.
Final Recovery
http://downloads.zdnet.co.uk/0,1000000375,39125766s,00.htm
is worth the money if you're really stuck. I've used it many times with great success.
Let us know how you make out.
Jim
Final Recovery
Jim
